![]() | Home > Maintenance & Mods (L322) > Steering track rod end gaiters |
Do you mean the ball joints on the track rod end or the steering rack gaiters?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Track ends removed from hub, then remove the trackrod end from the rack end, undo the gaiters and pop them off... it sound easy but rarely goes the way you want when it's jacked up on the drive...!! A motor factor should be able to get them, or the main dealer... |
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 213 ![]() ![]() ![]() |
Sorry….wasn’t absolutely clear…..it’s the steering rake gaiters that are leaking…. |
I’ll check the fluid as suggested. Thanks for the tip |
