Home > Maintenance & Mods (L322) > Brakes : What’s this green tube? |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 265 |
Please would someone be able to say what this small green tube is. It appears to be going to the brake callipers on the front near side ( passenger side ).
13th Jun 2022 12:50pm |
Thanks @Diesel-Dave. Is the green tube a protective sheaf or is that the whole thing ? It seems so flimsy that I wonder if there is a electrical wire inside the PVC tube. TDV8 4.4 2012 |
13th Jun 2022 1:13pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1320 |
Wire inside, once pad wears down to the wire, it goes open circuit and brings in your dash light |
13th Jun 2022 1:15pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 789 |
The green sheath is the whole thing.
13th Jun 2022 1:18pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 451 |
Yes its a protective cover, there is a wire in there but its only a sensor wire, IE when the sensor on the pad touches the disk the ECU gives you a message you have worn pads. I never like to say you’ll be ok to leave it with brakes, however the worse you could get is a false worn pads warning, or none at all if broken then the pads touch the disc with a scoring noise as in the old days. |
13th Jun 2022 1:20pm |
Thanks everybody; I’m feeling reassured! TDV8 4.4 2012 |
13th Jun 2022 2:01pm |
13th Jun 2022 2:31pm |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 274 |
Mine was fine with one of the sensors off for about a month - no warning light or anything. |
13th Jun 2022 9:34pm |
