![]() | Home > Technical (L322) > RRPhil or other ZF 6 speed experts? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8692 ![]() ![]() ![]() |
What makes you think it's the gearbox..? Pete
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 62 ![]() ![]() ![]() |
Purely on the basis that this was the identified cause in the case that i can find that is closest to mine. Other than the gearbox I have checked for binding breaks , heat shields and the prop centre bearing - they all seem fine. In the absence of any error codes I am stumped. If it's not the box then what to try next? Diff? Transfer case? |
Is the noise speed related, ie does it change with engine speed or vehicle speed..? Pete
It's definitely road speed - only happens below 15mph and never above |
What happens if you knock it into neutral and glide..? Pete
I tried to do it but it is impossible - it only happens when going uphill at low speed - putting the car into neutral in those conditions and it just stops |
Well I can't help with what that is but I am pretty sure it's not the gearbox, just doesn't sound like a gearbox issue if it is working fine...
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1007 ![]() ![]() |
From data kindly collected by forum members using the IIDTool it would appear that the torque converter lock-up clutch on 6HP26X transmissions fitted to the L322 isn’t applied (in controlled-slip mode) until the transmission is in 3rd gear – typically 24mph+ at light throttle.
You could also send your Mechatronic unit up to Pete Stirrup at Valve Bodies UK (https://www.valvebodyuk.co.uk/) to have it tested on one of their Hydra-Test machines, to see if it gets a clean bill of health.
Many thanks Haylands & Phill - I think I need to read some live values/do some data logging to try and work out what's going on |
