Home > Maintenance & Mods (L322) > 150K miles coming up soon
2010BlackL322
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Santorini Black
All,
The L322 AB Black will hit 150k miles soon.
I religiously change fluids every year, engine, gearbox, transfer box and diffs. Yep, overkill, but zero harm to change it every 12 months around MOT time.
Thoughts on preventative maintenance items I should replace now before they hit their end of life. Yep, I know “ain’t broke…”
Braking system is getting a full refurb next month.
Recommendations to what else to do?
Thinking fuel injectors, pulley bearings, and viscous fan bearings, they are noisy, water hoses.
Thoughts, thanks
Mark Check out my YouTube channel
https://youtu.be/UHBbLWZXw4A
Post #634846 17th Jun 2022 3:19pm
JayGee
How deep is your wallet and how many miles are you doing a year and how long are you intending to keep it?
Easy to spend serious £££ replacing stuff as preventative maintenance but unless something is showing signs of failure ( like the Aux belt and running gear are) I'd leave alone. Mind you if you are doing the aux belt the major work is getting to it so it's maybe worth thinking about replacing the alternator and waterpump while you are at it.
I'd think about 2x year oil change unless you do very low miles. 2012 TDV8 Vogue (L322)
Post #634850 17th Jun 2022 4:53pm
2010BlackL322
Thanks, clearly don’t want to go silly, as I say, “ain’t broke” but the bearings at the front need doing, so.
Yes, sorry, forgot to mention, oil changes every 3-4K, but it only will do 8K this year, then at MOT time, Nov, all fluids changed. Thumbs Up Check out my YouTube channel
Post #634851 17th Jun 2022 5:03pm
JayGee
Front aux belts, bearings and tensioner are a normal replacement / service item at higher miles. Don't delay if they are noisy. 2012 TDV8 Vogue (L322)
Post #634852 17th Jun 2022 5:11pm
2010BlackL322
Thumbs Up agreed, as they are going in there, that’s why I want some advice on what else to do while is apart. Check out my YouTube channel
Post #634853 17th Jun 2022 5:18pm
JayGee
I'd defo do the alternator then at that mileage. Had the water pump done on mine as it was leaking but not sure if it's a common fail but they are not too expensive. 2012 TDV8 Vogue (L322)
Post #634855 17th Jun 2022 5:21pm
2010BlackL322
Thanks, thinking the water pump as a matter of course, alternator, probably pushing it now at 150k Check out my YouTube channel
Post #634858 17th Jun 2022 5:33pm
JayGee
Kicking myself for not having mine done at the same time as belts and water pump…. 2012 TDV8 Vogue (L322)
Post #634874 17th Jun 2022 6:51pm
2010BlackL322
Good call, thanks Thumbs Up Check out my YouTube channel
Post #634896 18th Jun 2022 8:35am
kevinp
I've just done everything on the front of my engine mate, all pulleys, tensioner, water pump and while I was there the alternator as well.
I can't stress enough to get genuine parts though. I was sent a pattern tensioner and the quality of it compared to a genuine was was terrible.
Post #634901 18th Jun 2022 9:25am
garyRR
Starter motor maybe too. They get a lot of abuse turning a 4.4L engine.
And also a full automatic transmission service plus mechatronic sleeve, valve seal and new sump. 2015 Range Rover Autobiography 4.4 SDV8
Post #634907 18th Jun 2022 10:27am
2010BlackL322
Gearbox has been flushed and new sump and filter. Agreed genuine all the way 👍🏻 Check out my YouTube channel
Post #634922 18th Jun 2022 11:39am
Front seat filters...? Pete
Post #634925 18th Jun 2022 11:57am
2010BlackL322
Already replaced when I changed the fan motor over 👍🏻 Check out my YouTube channel
Post #634926 18th Jun 2022 12:00pm
Vent on air suspension pump and change/dry the dryer medium...? Pete
Post #634928 18th Jun 2022 12:03pm
