Home > Technical (L322) > No air conditioning!
Cedwat
France
Hi,
This morning my airco doesn’t work and there is no ventilation.
I have a l322 5.0 supercharged.
Any idea what I should check first ?
Thank you
Cedric.
Post #634918 18th Jun 2022 11:34am
So what doesn't work exactly, the whole unit? air comes out but warm? no air?
Be as descriptive as you can... Pete
Post #634924 18th Jun 2022 11:55am
Cedwat
France
There is no ventilation at all (no air coming out). Even when I push the “max air co” button.
Post #634932 18th Jun 2022 12:23pm
First off try a battery reset, check the WIKI for how to... Thumbs Up Pete
Post #634935 18th Jun 2022 2:01pm
Cedwat
France
I’ll try that when back home. I don’t want to risk a breakdown when away from home.
Post #634937 18th Jun 2022 2:43pm
Cedwat
France
Mmm. Can’t find it in the wiki ?
Post #634938 18th Jun 2022 2:48pm
Turn off ignition, take keys out
Wait 20mins
disconnect neg terminal, then disconnect pos terminal
touch both terminal together
reconnect pos first then neg...
See if that works... Thumbs Up Pete
Post #634945 18th Jun 2022 4:11pm
Merchy
I am not an expert, but If the above does not work then - Do not take as gospel, check first -
Fusebox in passenger compartment, should be fuse number 34 for 'Air Conditioning, Blower, Heated Windshield' Taken from l322 list of fuses and relays ( 2002 to 2012 )
Fuse No 64 ( Heater blower motor – front )
Climate control panel fault, as all functions of the climate control are operated through a PCB built into the control panel, not 100% sure about 2010 to 2012, but I think this is the case.
Multi stage resistor ( Hedgehog ) fault
Hope this helps
Post #634972 18th Jun 2022 10:01pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
In order of ease to fix
Fuse
Final stage resistor
hvac panel
Blower motor
Post #634983 19th Jun 2022 6:46am
