|  | Home > Technical (L405) > Camshaft position sensor seals/gaskets/o-rings |
| Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 257      |
 While having my alternator replaced due to a significant leak from the RH timing chain cover, the mechanic found the camshaft position sensor seals and the variable timing solenoid actuator seals leaking as well.
|  18th Jun 2022 3:35pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Your mechanic should have a stock of O rings, one should fit that...  | ||
|  18th Jun 2022 3:50pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Don't think you will have much luck on here, most have fatties powered by the devils brew... very few petrols.... Pete
|  18th Jun 2022 4:01pm |
| Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 257      | I know. Worth a shot though. Dan. 🇨🇦 2013 L405 5.0 SCV8 | ||
|  18th Jun 2022 5:04pm |
| Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 257      | So I pulled a sensor out, the RH upper is the easiest and took it to my local auto parts store to see if I could match the o-ring. They didn’t have a new sensor in stock to compare too.
|  18th Jun 2022 9:03pm |
| Posting Rules
