Home > Maintenance & Mods (L322) > Foam rubber blocks at rear of bonnet
Page 3 of 3 <123
kevinp
Thread resurrection I know, after collecting my car from a repair from a MD, Censored I noticed a loud whistling noise from the nearside front wing when travelling at speed which wasn't there before they laid their mits on it. Turns out they had dislodged the top wing insulator which had then fell into the hinge area of the door.
So yes it does do a good job of keeping wind noise out. In fact without it fitted you can look right through to the front of the bonnet. Might as well get the other side as well because it also is falling to bits.
Post #634905 18th Jun 2022 10:19am
Are you sure it wasn't whistling because of where it had been dislodged to..?
I also think if you remove one you have to remove both or you will get wind noise...
Try with them both off before ordering new.. Thumbs Up Pete
-Click here for Thread-
Post #634906 18th Jun 2022 10:26am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Thanks for resurrecting this thread!
I have the disintegrated foam thingies and was planning to replace them… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #634910 18th Jun 2022 10:49am
kevinp
Hi Pete. It had broken into two pieces and fell down by the door hinge. I've just used some UHU glue to fasten the pieces together and I'm going to refit it and see if the noise goes away.
The new parts are £40 odd quid each so if the noise stops I'll leave it until they completely disintegrate.
Post #634913 18th Jun 2022 11:13am
It's obviously a car specific problem, my 2002 ones had long gone and never had any noise, the 2012 ones were pretty awful so I removed them and it was fine as well...!!
Weird... Pete
Post #634916 18th Jun 2022 11:25am
kevinp
Just noticed the left hand bonnet one is missing. The right one is all complete though. Censored
Post #634923 18th Jun 2022 11:45am
Merchy
Regarding RJH's post about earlier models not having them fitted, just looked at my 2006, nothing there, and absolutely no evidence of any glue ever being in that vicinity, so RJH is probably correct.
Just went out to check, not long after going out to look at my OBD port for that thread, methinks the neighbours now think I am losing the plot, bad news is I would agree with them Whistle Big Cry
Post #634971 18th Jun 2022 9:42pm
garyRR
JLR main dealer couldn't be bothered to check they'd mangled one adjusting my bonnet during repair following a head on collision (along with a bolt missing from the new front grille, part of the old front bumper left on my IVORY back seats and a wonky numberplate). I encountered a squeak when operating the door and a whistle when driving also.
So, a word of warning kids, don't necessarily trust paying a premium for main dealer to fix a car that they will do a better job. 2015 Range Rover Autobiography 4.4 SDV8
Post #634978 19th Jun 2022 12:18am
kevinp
After refitting the foam the noise has gone.
Post #635006 19th Jun 2022 2:55pm
JayGee
Mine's missing from the passenger side and I can definitely hear wind noise from that area and not from the drivers side so will try removing the drivers side one and to see what happens. 2012 TDV8 Vogue (L322)
Post #635046 20th Jun 2022 10:11am
JayGee
Drivers side removed and no noticeable noise today on the M-Way 2012 TDV8 Vogue (L322)
Post #635116 21st Jun 2022 11:51am
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Removed mine years ago, makes no difference at all. Thumbs Up
Post #635117 21st Jun 2022 11:58am
Page 3 of 3 <123
