![]() | Home > Technical (L322) > Air con intermittent - is this the PCV issue? 4.4TDV8 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
Sounds like it. Does it takes ages to go cold too?
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
From a cold start up, the car takes about 5-10 minutes for the air con to kick in. It remains working so long as I'm driving at speed.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8740 ![]() ![]() ![]() |
I thought it was called the RCV....
It could also be a low refrigerant charge. It'd be worth getting it recovered to check the charge weight against spec.before jumping in and replacing the RCV. |
