Home > Maintenance & Mods (L322) > Windscreen protection and insect damage - Driving in Europe
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
Over the past 2 months, I've made three trips to Europe in both our L405 and L322.
Both cars have received stone chips to the screens during the trips. The one on the L405 has now turned into a 10 inch crack, having switched on the air con after being parked in 30 degree direct sunlight - Won't do that again!.
Also, despite frequently stopping at petrol stations and cleaning off the dead insects, both screens now seem to have dead insect damage, pretty much engraved into the screen, and I can't seem to shift these marks - The screens seem permanently damaged.
Has anyone else experienced this?
Also, as both screens are now going to have to be replaced, I'd be keen to avoid this damage again - Are there any products on the market, which will reduce / eliminate this marking of glass and ideally (although I suspect unlikely) reduce the likelihood of stone chips?
Many thanks
Post #634997 19th Jun 2022 11:56am
Driving with a bigger gap between you and the car in front is the best way to avoid more chips, easier said than done on a lot of roads as someone usually fills the gap you have left... The other problem is the upright rake of the windscreen... nothing you can do about that...
As for the marking by bugs, try mentholated spirits, neat on the screen to remove marks and add a cupful to the windscreen wash, as well as additive... works for me... Thumbs Up Pete
-Click here for Thread-
Post #634999 19th Jun 2022 12:23pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
For bugs I fat a large beach towel, lay across the windscreen and soak with a hose. Leave it on for an hour or 2 making sure it’s wet and then they just wipe off.
Post #635000 19th Jun 2022 12:43pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Insects wouldn't cause damage to a windscreen, if anything is just the residue left from hitting them at 80mph then baked on by the sun. I'm a European trucker so know exactly what it's like to keep cleaning the windscreen. France have the right idea supplying 'raquelettes' at fuel pumps to clear the flies away, although very good at doing it, it doesn't get rid of the dead residue. I use a green scouring pad to go over my truck windscreen and does a great job indeed in taking away the insect residue. It doesn't even scratch it either, just make sure it's nice and wet and job done. Another good product that i use is fly-away from Chrome products, you'll get this from most services in the UK. Just spray it on windscreen whilst you fill up, then use sponge or the raquelette at French services and clears the screen from dead bugs in no time.
Post #635001 19th Jun 2022 12:59pm
aja500
Thank you all for your different ideas / methods - All sound worth a try, so a few good options to experiment with.
Many thanks again Thumbs Up Thumbs Up
Post #635007 19th Jun 2022 2:58pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
I always use an old stocking, (not mine..)
Post #635014 19th Jun 2022 6:05pm
aja500
Laughing Laughing Laughing Thumbs Up Thumbs Up
Post #635017 19th Jun 2022 6:50pm
I'm in the south of France at the moment and yesterday we had 40 degree weather...as you can expect we had many foreign body's on the windscreen... McDonald's wipes and water cleaned pretty well... ... - .- -.
Post #635018 19th Jun 2022 6:52pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
put 30 ml of ipa in spray bottle fill with pure water or filter water in a 500ml sprayer very good for ripping the guts off also use for cleaning the rest of the windows you will not use anything else use microfiber cloths .
also for the washer bottle i mix 5 ltrs up i use 50 ml of sonax and put in 20 ml of ipa fill up with filter water deionised water i always use this water when i wash the car on the final rinse no more streaky body
panels or glass new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #635021 19th Jun 2022 7:49pm
aja500
I suppose that's one way of dealing with the French Laughing Laughing
Post #635022 19th Jun 2022 8:06pm
aja500
Will give it a whirl oggy Thumbs Up Thumbs Up
Post #635023 19th Jun 2022 8:07pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Hi AJA, apologies I did say I would ask the guys who did my PPF about a product called ClearPlex which is a PPF for windscreens - it might be worth a look. Im back at REEP next friday so will ask about its suitability for a heated RR screen.
https://www.reepsouthern.co.uk/clearplex/ 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #635024 19th Jun 2022 9:02pm
p38arover
Australia
I assume you mean methylated spirits - unless you blokes in the UK can get a drinkable version of metho. Whistle Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #635026 19th Jun 2022 9:48pm
I couldn't spell either so it's spell checks fault...... Rolling with laughter Rolling with laughter Pete
Post #635028 19th Jun 2022 9:55pm
oggy
gtechniq that do ceramic coatings do a g5 g4 max repellency glass kit which is a coating you put on and it states easy bug cleaning new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #635042 20th Jun 2022 9:56am
