Home > Maintenance & Mods (L405) > Passenger door won't open
rtobrienra
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
Not sure how this happened yet, but my passenger door won’t open, from the outside or inside, all other doors work fine, tried battery disconnect, can't check the fuse as you can’t lower the glove box to access the fuse box due to the door being closed, suspect its the module or actuator but can’t access it
anyone any idea how to get this door open
Post #634873 17th Jun 2022 6:50pm
zoso
Scotland 2013 Range Rover Autobiography SDV8 Santorini Black
I had a similar issue with the front passenger door - same symptoms as you - wouldn't open from the inside or outside. Did a lot of searching and eventually found some Land rover site in the US that suggested this is a problem with the soft close doors and can be fixed with ECU update. I checked and although my car didn't have any ECU faults the GAP tool did indicate that an update was available for the passenger front door module. I contacted Patrick at GAP and he sent me an ECU flash for the door module which I applied. Initially that didn't work but I then did the ECU reset (battery terminals) and that cleared the fault. I'm not sure if an ECU reset would have cleared the fault (might be worth trying that first) without the ECU flash but the combination seems to have worked.
cheers 2017 4.4 TDV8 Autobiography
2016 4.4 TDV8 Autobiography - GONE
2013 4.4 TDV8 Autobiography - GONE
2010 3.6 TDV8 - GONE
2008 3.6 TDV8 - GONE
2002 3.0 TD6 - GONE
2006 Discovery 3 TDV6 S - GONE
2006 Discovery 3 TDV6 - GONE
2003 Discovery 2 TD5 - GONE
1999 Discovery 300 TDI - GONE
1998 Range Rover DSE - GONE
1997 Discovery 300 TDI - GONE
Post #635229 22nd Jun 2022 9:59pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Any results on this?
My son sees this at work and with SSD they can open the doors.
Post #635529 26th Jun 2022 7:22pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
My right rear door would not unlock without cycling the electronic child locks. I replaced the door latch in the door with a used one from EBay from a parts donor. No more issues.
If you get the door open, sort this out asap. The repair takes regular hand tools and patience. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #635576 27th Jun 2022 3:43pm
