Home > Maintenance & Mods (L322) > Classic[?] failures with 100000 Miles 10yo TDV8 FFRR...
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
OK, I knew what I was doing, 6 months ago, buying a 10 years old RR L322 2012 vogue with 160000km.
here is the list of my experiences so far :
- had to change the 4 tires that weren't the right size (255 55 20 in lieu of 255 50 20) --> 1000€ (1/2 taken by seller)
- oil leak on the oil filter - classic burnt gasket --> 1500€ (1300 taken by car warranty)
- last a week ago, 2 pneumatic shocks (the car was tipping to the left on its rear wheels) and a failing EGR that filled my DPF up the snuff, going full red alert on the dashboard and in limp mode, that will need replacement (EGR) and regenerating (PDF), that last episode will cost me a mere 5000€ (1500max taken by the car warranty)
a grand total of 7500€ of which i will have paid 4200€ Big Cry
SO my question is:
1- WHAT IS NEXT ?
2- WILL I have a reliable car now ?
I still love the car though (I heard someone say it's a disease ?) Rolling with laughter
----> see last post pointing to DrRob list of what to expect Bow down
Cheers "it needs some intelligence to undestand you may not have enough"
Post #635361 24th Jun 2022 3:34pm
Reliable..... Hmmm, let me think for a minute...... Whistle Pete
Post #635363 24th Jun 2022 3:47pm
CongoBoy
South Africa 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Rolling with laughter Rolling with laughter Rolling with laughter 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
2008 D3 HSE Stornoway Grey (UK)
2008 D3 HSE Izmir Blue (ZA/Zimbabwe)
1995 D1 300 Tdi (Zimbabwe)
Post #635365 24th Jun 2022 4:03pm
ergobyte
It can be seen as being a bit fun though... these are all textbook L322 failures.
I'm a fatalist !
once I've replaced all the breaking parts I'll have a new car, no ? Rolling with laughter "it needs some intelligence to undestand you may not have enough"
Post #635367 24th Jun 2022 4:13pm
Dolphinboy
have your oil cooler checked.
Post #635368 24th Jun 2022 4:18pm
ergobyte
that oil cooler with the textbook leaking gasket I've had already, so I'm good...I think Whistle "it needs some intelligence to undestand you may not have enough"
Post #635369 24th Jun 2022 4:24pm
Turbos next then.... Rolling Eyes Pete
Post #635375 24th Jun 2022 5:08pm
Then brake pipes, airbags, suspension bushes, battery, alternator, starter.... I can go on for ages..... Shocked Pete
Post #635376 24th Jun 2022 5:09pm
kevinp
Interested to know what the symptoms of the 'failing egr' is please.
Post #635384 24th Jun 2022 5:44pm
Merchy
Ergobyte, ignore Haylands, I think he's trying to give you a nervous breakdown Whistle IF....you have not had one already Rolling with laughter
Buying a fatty means it goes with the territory Big Cry
Post #635386 24th Jun 2022 5:58pm
ergobyte
Thanks Merchy,
I kind of did this post on purpose...
I don't blame anyone, I knew what I was doing but I wonder if everyone does?
It could be useful to have a recap of sort, something upfront on the forum...:
"You who intend to buy a fullfat with 100000Miles, here is what to expect and follow up close [here list with wiki pointers], If you're a full blown mechanic, you'll find everything here to help you DIY., If you're not, still a load of excellent recommendations by devotees that like you love their FF, yet sometimes cry at night." Rolling with laughter
and yes I will keep you posted on that happened (I asked the mechanic to keep the failing parts so I can make some pictures
Cheers
Sylvain "it needs some intelligence to undestand you may not have enough"
Post #635396 24th Jun 2022 7:14pm
ergobyte
that's the thing...the only warning I had was a direct full red "DPF full, go to dealer" warning and a car in limp mode. I never had a DPF yellow warning.
Went to the dealer and that's what. Couldn't do any regen in limp mode (I checked on the wiki) so basically I was Censored
The head mechanic told me that a failing EGR like mine will never recover and its "warning" is impossible to erase. "it needs some intelligence to undestand you may not have enough"
Post #635398 24th Jun 2022 7:23pm
ergobyte
ergobyte wrote:
Thanks Merchy,
My bad ! DrRob did the Job !
see here :https://www.fullfatrr.com/forum/topic44115.html?highlight=4+4&start=75 "it needs some intelligence to undestand you may not have enough"
Post #635434 25th Jun 2022 1:01pm
