Home > General > A plea to all members on your post title choice
Dear esteemed fellow FFRR fans,
We have built up quite a membership now and have thousands of posts with some great topics, hints, tips and helpful advice. Cool
Quite often someone new comes to the forum with a question that has been asked before and we tell them to search for it. This is fine and makes perfect sense, however if the topic they are looking for is not easy to find it's inevitable they will probably create a similar thread, or go away unhappy and unable to fix their issue in time. I know it won't always work as we planned but if we all started our threads with a meaningful title that talks to the content then when people are searching (you included) it's going to be easier to find.
For example, if I needed to find out information about faulty steering columns, do a search, which do you think is gooing to mean more to me...
1. Steering Column Fault: Any ideas?
2. Aaaarrggh! It's broken again!
Very Happy You get the point.
We all do it at times, I know I have, lets make this forum even better, it has a great reputation for the friendliness of the members and the degree of useful help we all have collectively.
I may from time to time tidy up a post title so that it has more meaning, so don't be surprised!
Thanks everyone
(Adam) Discovery 4 HSE
1993 90 Tdi
Post #63543 12th May 2011 8:57am
Thumbs Up ... - .- -.
Post #63545 12th May 2011 9:01am
supershuttle
I think I need some reassurance around the search function as I may be doing it wrong for example if I put in, as I did once, "Tailgate lock is loose" I get reams of stuff - most of it not related to loose tailgate locks.
Is it me ? Big Cry
Should I get my coat? Geoff
Post #63547 12th May 2011 9:15am
not you mate, the search is a bit pants and you do have to read reams before you get the answer you need... ... - .- -.
Post #63548 12th May 2011 9:20am
The key is to simplify your search and just put in "Tailgate", limit it to post titles and not contents also. Discovery 4 HSE
1993 90 Tdi
Post #63549 12th May 2011 9:23am
supershuttle
Thats the sort of help I needed - thanks.
I had assumed that the more specific you make the query i.e. including "Tailgate", "lock" and "loose" it would tighten it but it actually looks for all three words individually.
i did incidentally try "search" in the search before I posted because I'm scared of Stan Very Happy Geoff
Post #63555 12th May 2011 9:31am
Fox
On most forums I use, I find the search function is not quite as easy to use as google, then type in the problem area and add the forum name. (ie: Steering Column fullfatrr)
Out of interest, typing "Steering Column fullfatrr" into google gives the first result as Dan's post in the technical section of this very forum. Thumbs Up Job done.
Post #63556 12th May 2011 9:38am
Avi
2006 Range Rover Vogue Td6 Alveston Red
+1 . This is how i search all forums Smile
Post #63558 12th May 2011 10:11am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
True, you can actually use 'site:' as a Google modifier as well as the standard boolean operators and quotes etc.
Example site:http://www.fullfatrr.com "rubber mats" -ebay would search the site for anything with rubber mats in (exactly) but excluding anything with ebay in
Think the quotes approach and +/- also work in the Fullfatrr search too.
Anyhoo, good point Adam- I've also probably used some vague titles!
Post #63561 12th May 2011 10:21am
Laughing Wink
Post #63578 12th May 2011 12:45pm
Nice tip happymadison Thumbs Up .
Post #78627 1st Sep 2011 11:52am
