Home > Technical (L322) > 2011 4.4 tdv8 - Strong smell from exhaust |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16163 |
No codes at all? |
24th Jun 2022 1:04am |
Garnerj Member Since: 07 Aug 2018 Location: Milton keynes Posts: 48 |
Just the usual ones like random stereo ones and a few other bits. I reset earlier and going to take it for a drive again in the morning to see what’s come back. |
24th Jun 2022 2:53am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2637 |
Mine smells all the time - as have all my diesel cars ( not that this helps)
24th Jun 2022 8:39am |
Pysta Member Since: 05 Sep 2021 Location: Bra Posts: 24 |
Does it smell only from the exhaust (interrupted regen, shot DPF ...), or under the bonnet (fume leak around EGR, under injector, headers)? |
24th Jun 2022 8:40am |
I’m suspecting you will have a P3040D code in there when you check later… The temp sensor fails lots on the 4.4 which leads to overfueling and stinks like an old ice cream van! |
24th Jun 2022 12:42pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1086 |
So you think the quality has got worse now we dont have Russian diesel? I think not 2018 SE SDV8 4.4 Byron Blue |
24th Jun 2022 2:18pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4215 |
Listen to Craig 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th Jun 2022 7:57pm |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 |
I had the exact same issue, no codes but changed the sensor anyway just in case. Made no difference whatsoever 2011 TDV8 Vogue SE |
27th Jun 2022 8:10am |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
Camshaft position sensor? Christian. Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
27th Jun 2022 9:54am |
No, this is the sensor located in the N/S exhaust manifold 2011 TDV8 Vogue SE |
27th Jun 2022 9:58am |
