![]() | Home > Maintenance & Mods (L405) > Rear Seat Stuck in down position |
karba78 Member Since: 21 Mar 2020 Location: Plaisir Posts: 105 ![]() ![]() ![]() |
you may have to short the wires that go to the electronic box below the foot under the carpet in front of the seat.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1342 ![]() ![]() |
Try moving the front seat all the way forward then try again with rear seat 2018 SE SDV8 4.4 Byron Blue |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 99 ![]() ![]() ![]() |
My right rear portion does the same..
rockodrama Member Since: 29 Jun 2022 Location: Alabama Posts: 5 ![]() ![]() |
this rear seat is giving me a massive pain LOL. Today, Ive managed to remove the front seat, to work my way under the carpet to remove the rear seat module (looked a little corroded so i cleaned it up), and struggling abit trying to read the wiring diagram to see which harness/wire i need to try to give some power to. I will keep reviewing the manual over next few days. In the meantime, I'm going to put everything back together and pray to the LR Gods your trick works @marcochezzi |
No luck, I think I’ve tried to jump every wire I see in the schema that says recline/incline with no results. Will insert pic if anyone has any guidance. It appears someone has already spliced something on the wire harness that goes into the module. My last attempt is gonna be take the right rear seat module out swap it and see if the seat lifts if that works I’ll try to wire both seats to the same circuit. So both buttons raise both seats. Will keep updated. |
Still trying smh. Ended up going through the back of the seat to try to turn the axel that controls the recline/incline can't seem to move it with vice grips either direction or find a release on either side. |
