![]() | Home > Maintenance & Mods (L322) > Air leak after lifting Range Rover 2012 Westminster |
Height sensor rods twisted / disconnected? |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 793 ![]() ![]() |
Probably haven't done anything wrong, mine did exactly the same, put it up on a hoist then heard the leaking air when I put it on the ground. Most likely just a 10 year old air bag giving up after being extended. |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Had the same 2 days before setting off for France.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Had same. Old bag, replaced with one from Advanced Factors. Just the bag |
Upnorth Member Since: 13 Mar 2021 Location: Orkney Posts: 24 ![]() ![]() ![]() |
Thanks for the replies, I can see what you are all saying about 10 year old bag leaking. I will lift it up again and look for a split once it has deflated, with the o/s/f leaking would it make the o/s/r deflate also or should that stay inflated?, I did not think to mention that’s what was happening.
Looked at bag it’s got some small marks in it and a line of rust, from the btm seat I presume. Decided to change both fronts and shocks complete because previous owner replaced rears about 3 years ago due to shocks leaking. |
A soap spray will confirm any leaks - or not. all you need is a hand spray bottle (an old cleaning product spray bottle is ideal) with some extra-foamy surfactant, I use the foamy car cleaner stuff but washing-up liquid will do, just use it at a higher concentration than my usual 10:1 with the high-foam stuff. Spray the airbag and leave for 5-10 mins, you'll see a cluster of bubbles if you have a leak.
Thanks, I took a photo of the btm of the air spring and it looks like the rubber has come away from the base so that’s where the leak must be. |
Personally I'd confirm it, but if you're happy - it's your money!
Thanks I will do the soap test tomorrow to confirm where the leak is coming from, I have looked at the other side the base is the same if not worse with the rust the rears seem to have a nylon base hence no rust. |
Yes it is quite obvious with a picture. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
If you use washing up liquid then please make sure you rinse it all off afterwards....
Thanks I’ve just looked closely at the other side and whilst the air bag is still on it’s mounting a lot of bubbling of rust is evident. I presume I have the adaptive struts from this picture.
