Home > Off Topic > "G4 Black" Land Rover D3 Project
Page 12 of 15 <123 ... 1112 131415>
Heh 3R10 glad you like the D3. Its was an idea that seem to catch the attention of the forum so I keep on posting for those that have been following so far.... Very Happy
Post #62892 6th May 2011 8:14pm
OK so the M6 RIVNUTS are was advised to purchased are a size too big for the bolts supplied with my second-hand RAI Big Cry
Do I have the wrong bolts or are the correct RIVNUTS M4 or M6 or similar......?
Gaz
Post #62978 7th May 2011 3:04pm
OK Rivet Nut Tool arrived and therefore this morning I set out to bolt the RAI on to D3 properly this time:
M6 Rivet Nut Tool Head and M6 Rivet Nut attached
You have to start somewhere. Grip Grille with hand behid back and pull upwards hard!
I used Clear Duck Tape to mark the holes accurately:
I i drilled small pilot holes then upped the anti to the 9mm bit and smoothed of with a round file before tapping the rivet nuts.
THe Rivet Nut Tool was easy to use and worked like a dream (bargain)
I used stick on draught excluder to create a dust proof cushion between car & RAI:
On cars as well so double layer effect (The barrier seems effective and will be splashproof as well)
Nearly finished - my new M6 bolts had bolt rather than screw ends (not ideal)
Get some of this its fab.
Works a treat.
The G4 Black Overland is nearly finished...
Still have the Monster XGT Driving Lamps to fit though Very Happy
Post #63573 12th May 2011 12:32pm
Fox
How deep are you going?
Are you going to have to look at the engine electronics as well?
Post #63589 12th May 2011 1:25pm
So far nearly £5k spent including A Bar and XGT's not yet fitted Shocked Big Cry
May get it chipped before I stop though.....
Oh & tints Whistle
Post #63601 12th May 2011 2:57pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
and winch....
looking good... Thumbs Up 2004 black Vogue TD6
Post #63644 12th May 2011 6:35pm
Still undecided re the Winch.... Confused Confused Confused
Post #63651 12th May 2011 6:58pm
Lightforce 240 XGT
Finally the Legal A-Bar arrived and I have now fitted the Lightforce 240 XGT Lamps - About the brightest around....
Not exactly an undercover vehicle:
Post #65593 24th May 2011 7:14pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Ummmmmmmm not sure on the look, they are big Rolling Eyes
But what do they look like from inside, in the dark? Thumbs Up
Post #65594 24th May 2011 7:31pm
Fox
Think I'm with nbunney.
I'm sure they're great in the dark, but for most of the time you're driving around with two moons stuck on the front when you don't need them.
Out of interest, does the A-Bar reduce the approach angle?
It looks a little low.
A side on picture showing that and how far the lights stick out to the front would be nice if you do requests... Laughing
Overall I think I prefered the look without the bar and front lights. Sorry, personal opinion and all that. Embarassed
Post #65599 24th May 2011 8:04pm
All opinion welcomed warmly Thumbs Up
Yes it does reduce approach angle slightly but not much and they are set back on the bar so do not stick out too much. You just see the top of the two lights from inside
Pictures of the Chorleywood Illuminations when they are wired in Laughing
Post #65601 24th May 2011 8:08pm
AMD
Gaz, I think your motor is brilliant, just the right mix of colour, moderfication all tastefully done, it looks like a factory specced vehicle and something ready for the special forces to use in Libya....that was until you fitted the chrome A frame and lights, sorry mate, just my opinion. I still admire your work Smile Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #65607 24th May 2011 8:16pm
AMD,
You may well be right.....
Still not sure myself but I wanted big driving lights and was a sort of mission I guess.
I am going to get A Bar powder-coated and may keep the black Covers on for general use so maintain the steath combat look!
Tweeking is what its all about Thumbs Up
PS: Lights under Bar is another option?
Post #65612 24th May 2011 8:23pm
nbunney
Powder coated in black? Now that might look good Thumbs Up
Lights under umm how about 2 more? Whistle
Post #65615 24th May 2011 8:30pm
No Nigel six lightforce is enough or I may get a power cut Rolling with laughter
Post #65622 24th May 2011 8:39pm
