![]() | Home > Off Topic > Solar PV? |
| SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457
anyone on here a solar expert?
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1422
I have a 13 panel system with a 3.6kwh inverter , no fit, no battery, so use it or lose it.
| SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293
I had 4kw installation with a battery Pack fitted 7 years ago at a cost of around £8k With the Feed in Tariff & taking into account the savings on taking power from the grid the break even point was around 5 years.
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
DONT try to make it 'stand alone' you need it grid tied to supplement your energy input from the grid. Grid tied inverters normally have an output for emergency power cuts, I have a 13 amp socket on mine that allows me to run essential items. If it's not grid tied you need an inverter capable of supplying you maximum load, theyre relatively inefficient and expensive.
| Dan_Veluwe Member Since: 04 Dec 2021 Location: Highlands ( Veluwe) Posts: 172
"Grid tied inverters normally have an output for emergency power cuts, I have a 13 amp socket on mine that allows me to run essential items."
It sounded like you were talking about an off grid inverter rather than a grid tied one hence my comments. All grid tied inverters that i know of have an emergency output. It has to be done this way due to regulations, if engineers switch off the grid supply, the last thing they want is everyone's inverter back feeding, it would be shocking LOL
You need approval from the DNO, 3.5 kW you usually get ok, above 3.5 kW they may object. On my inverter I can limit the export to 3.5kW max if I wish or any level as required. It is worthwhile having a bigger inverter to cover surges in demand eg kettle on, oven on and a couple rings going, saves drawing on expensive grid power. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
| All times are GMT |
