![]() | Home > Technical (L322) > blue smoke on cold start but only some times |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8630 ![]() ![]() ![]() |
How much smoke, can you see anything in the mirror? and for how long? Pete
J9Billyeck3 Member Since: 15 Jul 2022 Location: blackburn Posts: 3 ![]() ![]() ![]() |
it is totally random and there is no pattern to it, some times i can go 4 or 5 days without smoke and then get 2 or 3 days with smoke, the amount of smoke is complete random as well, some times i can just about see it then some times it covers the street ,
Hopefully someone who has had similar will be along shortly, if not it sounds like you need a good independent garage to take a look...
yeh iv had 3 local independent LR garages look at it but they just dont listen,
Jimmy123 Member Since: 14 Nov 2020 Location: lancashire Posts: 4 ![]() ![]() |
My 4.4 na does it when I've had the revs up around 5000 revs in the morning, on start up in the evening i sometimes get the same, it just wafts out with no force. |
You will probably find more info on the Jaguar forums over here and the US forums for the RR as it was far more common over there... |
Jamor Member Since: 18 Aug 2024 Location: Łódź Posts: 2 ![]() ![]() |
Good morning, how did the situation develop with your problem? Was it successfully resolved? I have the same thing in my 4.2sc in my Jaguar and I have not found an answer anywhere on the forums, the steps I did the same as you. |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 671 ![]() ![]() ![]() |
All the usual will apply the SC isn't that different in that respect from other petrol motors, blue smoke is most likely oil finding it's way into the cylinders.
Temporarily remove the PCV pipe from the throttle connector (and seal the TB connection ) and let it vent to the air or into a 'catch can' . If this fixes it you can narrow your diagnostics to the PCV system. 2012 TDV8 Vogue (L322) |
In my case it is that it is the oil typically from the PCV system through the pipe that collects in the throttle elbow. Compression checked, after 12b evenly, plugs new, at full load the streak does not leave, collects oil when driving calmly and at idle. PCV valve replaced with original but I think I will repeat this action and certainly install Oil Catch Tank on this tube, I will see what amounts of this oil will collect. |
