![]() | Home > Technical (L322) > airco when started, driving only hot air |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
4.4 tdv8? Could be the known valve failure on the air con compressor Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New pump sorted mine. Used Advanced not Genuine. Same part, different box |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Thanks Dr. Rob, in fact it's a 4.4 petrol AJV8. We will look into this valve failure.
Not sure if it applies to a petrol one. Only know it’s common on the 4.4 tdv8 |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Does the air conditioning no longer work at all? Does heating work properly? There's not too much which would cause the issues other than:
Thanks Gary,
In the IID tool go to live values and then the full list. You can view the evaporator temperature, clutch status, pressure, cabin temperature.
to no avail. On my IID in the live values these items are not available in the complete list, or I am to dummmm to find them.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8793 ![]() ![]() ![]() |
Couple of things to check, is the aircon dripping from under the car, if not the drain could be blocked and the condensate is backing up and freezing so stopping air getting through...
Thanks hayland, yes checked both, clean and works |
Oh well... it seems a very funny issue, good luck I hope you sort it soon... |
