Home > Technical (L322) > Parallel wire to Starter solenoid switch
Bogi 6357
Hi
I’ve been having starting no crank and click issues on my
2008 TDV8 for a while , it’s had batteries , starters , etc , I decided to look at this myself ,
Long story short , I wired in a push button to the starter which works every time !
So I would like to run a parallel wire from the engine fuse box ,starter circuit , I’ve found a similar thread
Where they are tapping into the starter trigger wire which exits from the under bonnet fuse box
My question is which one is it 😀
I have attached an image of my fuse box and wires , or if you can guide me to a diagram
As I can’t find anything online
Thanks
Ian
Post #637080 17th Jul 2022 12:59pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
What engine, what year etc, need specific information BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #637085 17th Jul 2022 2:10pm
Bogi 6357
Hi yes it’s a ….year 2008 L322 3.6 TDV8
Cheers
Ian
Post #637088 17th Jul 2022 2:50pm
RRYorks
United Kingdom 2018 Range Rover SVAutobiography SDV8 Loire Blue
Are far as I can work out, you would need to intercept the wire from the Engine control unit to the relay.
Plug C0572, Pins 19 (Black/Yellow) and 25 (Red/Blue), I would assume one is earth and the other is energised by the ECU to call the relay
No warranty implied or given! use this info at your own risk Wink
(Of course, it might be the relay which is causing the problem?) 2018 4.4 TDV8
Post #637317 19th Jul 2022 2:41pm
Bogi 6357
RRYORKS
thanks for this I really appreciate the effort .
From your Diagram , it’s relay 6 , will check this myself
And the trigger or signal wire don’t know the terminology 😀 is on connector C571 red and black wire , I’ve attached an image of my fuse box with the wire I would splice another in to run to solenoid switch /trigger on starter motor
I will trace this wire back to the starter solenoid to make sure it’s the one I’m after , it would normally go to the garage
But I’m not having a 4th starter motor fitted , I measured the voltage at the starter solenoid switch/trigger wire and it was 9V
I wired in a push button start and that activates the solenoid every time 12.4 V when activated ,
Battery seems ok at 14.2 V when running ,
Kind Regards
Ian
Post #637337 19th Jul 2022 8:28pm
