![]() | Home > Technical (L322) > Front electric seats stopped working. |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 208 ![]() ![]() ![]() |
Have you checked all the plugs under the seat? If it's not a loose plug I think you may find the seat ecu has expired.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Check the fuses first.
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 785 ![]() ![]() ![]() |
Thanks for that guys. I'll try the fuses again just in case when i get time. They only stopped working when i fitted the deployable sidesteps, and another thing I'm going to try when i get time is to swap over the plugs from the steps back to the ECU under the fusebox and see how that works. If not I'll go down the new ECU under the seat route. Nice to know they are cheap. |
