Home > Maintenance & Mods (L405) > TV Screen removal
Paddy
England 2007 Range Rover Vogue TDV8 Java Black
TV Screen removal
I am looking at a RR Autobiography which comes with the tv screens that are mounted to the rear of the front seats (Not the headrest ones).
Are these easy to remove and replace with a inconspicuous blanking panel or speaker?
I can only seem information on the headrest versions.
Thanks for the help as always
Post #633044 27th May 2022 8:53am
M11buc
United Kingdom 2019 Range Rover Autobiography SDV8 Santorini Black
Can I ask, Why do you want to remove the screens ? I would not think it would be a easy task as they tilt / move as the front seats do, so expect there is a complex mechanism in the seat back and also these are wired up to a slave and master controller ( under N.S.F seat) that would need to be disconnected. These units talk to a lot of other units in the car like the Center info display, radio etc. if disconnected May cause fault codes and other parts of system not to work. Not tried it but that’s what I think.
Post #637124 17th Jul 2022 6:09pm
Paddy
Thanks. I have got used to them now. I wouldn't neceserily spec them but I think it's just the fact I am not used to seeing them that put me off.
Post #637164 17th Jul 2022 9:44pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Digging out an old post, I need to remove a screen on the driver seat, any suggestions?
Post #720732 3rd Jul 2025 8:26am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
It pretty easy, small tab on top of the bracket where it joins the seat, then a couple of torqs screws. I will see if i can find an old thread.
It will leave a space on the speaker grill once removed.
Post #720734 3rd Jul 2025 8:51am
