![]() | Home > Maintenance & Mods (L405) > MY18> Code Reader |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1422 ![]() ![]() |
I use this, it clears DTC found it very useful, it also has other functions read the blurb for full info
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2622 ![]() ![]() |
Thanks, I’ll have a llook. |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
I got this tool and it doesn't support <2018... I wrote to them and the reply was: "Kindly note that AP200 can not support vehicle of 2019 or newer one, thus your vehicle can not be present. If possible, you can try other device such as MX808 for use." Do you use the generic app? The Land Rover one doesn't even let me input my VIN... |
It certainly works for me.
Yes use Landrover, if I do an auto scan it detects my vin but I do get a decode error. So I use the Manual scan and pick New Range Rover (its not the 460 lol)
Then pick 2016-
Then pick my Engine
Then do a DTC scan, afterwards you can do a quick erase to see if code clears or save a pdf report etc
What I like about this is if you have different models in the LR marque it will also work for them at no extra cost. If you have a different marque in the family you just pay an extra £20 or so and it covers all the models of the other marque you select. Its a very cheap DTC reader and code eraser with other options which I haven't needed to use yet, and recently when Landrover remote was frozen (my car was somewhere else lol) and not able to use Guardian mode! I used the AP200 to clear the DTC on the Telematics module and all returned to normal. It found the DTC and issue I had with my compressor and also turbo actuator issue. The Gap tool doesn't support my vehicle so this works for me. 2018 SE SDV8 4.4 Byron Blue |
Thank you, I thought about doing this, the problem is that my engine isn't mentioned! Being a P400e, the car has a 2 liter petrol engine and an electric motor... Maybe I should choose an Evoque? |
Adara Is it not the 2.0 GTDI option in my 3rd picture? 2L engine fitted also to Evoque and Disco sport? Try the manual set up as discussed.
You are right, thank you, I used the 2.0GTDi option and it worked!
Glad it works for you Adara.
Thank you! I will look at the forums, especially since my wife's car is an I-Pace... Now, it would be amazing to use the Autel for her car too! |
Yes it will work on your Ipace.
