![]() | Home > In Car Electronics (L322) > Radio doing nothing |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8798 ![]() ![]() ![]() |
Don't think about selling it when you are in ear shot, they just keep going wrong when they hear you are going to sell... |
Joek0 Member Since: 29 Jun 2022 Location: Tipperary Posts: 50 ![]() ![]() |
So I reset the battery this evening.... but no luck |
The polymer 'cable' that the MOST uses would be more susceptible to heat than the copper wiring, it does sound like heat damage given the only thing that has changed is the welding to the body. To coin a phrase, if you hear hooves, think Horses, not Zebras. The most likely explanation (heat damage) is the most likely cause. Get yourself a MOST test loop from fleabay and connect each module's MOST with it, if everything comes back to life - then the module currently bypassed has an issue, if not, then it's the polymer fibre 'wiring' at fault. |
Ok cheers phoenix |
You need to go to each module in turn, disconnect the MOST and connect your test adaptor to the cable, the radio tuner is behind the glove box so I'd leave that until last and start with the stuff in the NSR, there's no need to disconnect the screen as you know that is working... Have you been able to get any DTC's from the vehicle? |
I dont have a code reader yet, if I decide to keep it I will invest in one, that was my plan anyway.
It's a sign that the downstream module is communicating - the whole 'daisy chain' needs to be intact otherwise you get nothing.
I cant make that out phoenix its a bit of a blur |
Would it be worth a try doing the pen trick to see if it responds |
Try this:-
Nice one - what did you find? |
It was the Bluetooth module, I did the pen and tape and it came straight on.
It works with most phones - mine is a OnePlus 9 and it works as expected. Worth checking the tailgate seal for water ingress, the Bluetooth module is usually the first one to suffer. |
