![]() | Home > Maintenance & Mods (L322) > A Bit Odd |
Has someone attempted to cut the wiring to the door? check the rubber umbilical on the 'A' pillar for damage, if OK, take out the screw and check the connector behind the shroud is fully mated / not corroded. |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Do you have any way to see if there are any error codes stored, i.e. with a GAP IID tool or similar OBDII reader.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Have a look at Fuses 11 and 24, both 30A on the front fuse box. |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
Thanks for the ideas, will give them a look
Thanks to those who suggested the fuses, glad to say one 30amp fuse in position 11 later and everything appears to be working again |
Do you still have the blown fuse? does it look like it has a small crack or gently melted section across the middle, or is the middle of the fuse discoloured like a bad bruise? The first type of 'blow' indicates a repetitive or persistent overload, the second indicates a short to ground, usually due to cracked or damaged insulation or the harness rubbing on a metallic part due to restraints and hold-downs giving way over time.
Looking at the fuse it will be the more gradual overload as apposed to a big bang.
Well the good news is that with the sort of current involved, you could use a current clamp to measure the draw from connected consumers, which means you won't need to open circuits and have a slack handful of spare multimeter fuses available...
That's a good point, I'll borrow the clamp meter from work and do some investigation
Both those circuits involve motors, which can have high inrush currents, the fuse and circuit wiring will be need to be capable of (for example) powering both front windows at the same time. |
Yes that's true, the windows have been used quite a lot lately (especially as the air-con needs a re-gas) TBH I was thinking along those lines (i.e. windows maybe getting a bit sticky in the runners) so have been looking at some dry lubricant to do the said runners.
Believe it or not, they are not lubricated from new, its just the 'fur' that prevents friction as the window only touches small areas of the fibre, over time, this wears down and gets bunged up with general road dirt, bird muck etc. Ive had good results from taking them out and bunging them in the washing machine on a hot wash with as much washing powder as you dare... Obviously, make sure the mechanism is lubricated and not binding as well. |
Okay that's good to know (I'll wait until the wife puts on a "Dark's" wash and sneak them in) |
