![]() | Home > Technical (L405) > 2015 AB 4.4 cuts out when cold |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
If you have access to a diagnostic tool that can graph engine rpm then graph rpm from before starting to idling to check that the rpm isn't momentarily dropping to zero which would indicate a faulty crankshaft position sensor. It's such an easy check that it should be the first action whenever chasing the cause of starting or low rpm faults. |
as stated, would just be a guessing game without diagnostics sir... |
BuddySpire Member Since: 15 Oct 2018 Location: Sheffield Posts: 27 ![]() ![]() |
Been to Indy this morning and the fault code when check against LR database along with symptoms is suggesting wiring fault on fuel pump registering too high a pressure. Parts are only £40 plus hour fitting so trying that first.
