![]() | Home > Maintenance & Mods (L405) > L405 oil change |
| Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 257
Why? The dealer and shops don’t.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35875
oil changes on L405's are sucked up nowadays.. ... - .- -.
| DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 798
The sump nut now has some sort of rubber o ring moulded in other wise it would be new copper washer |
What model year? Dan. 🇨🇦 2013 L405 5.0 SCV8 |
2013 Td6 |
Not a fan of this method. How much sludge remains at the very bottom of the sump, building up over the years before becoming instrumental in blocking the turbo oil feeds and leading to an explosion in your wallet ? |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
None. |
Been proven on here many times over the years... Sucking gets 99.9% of the oil out, remove the sump bolt after sucking it up leaves like a 1/4 of a pint! and where the sump drain is means the new oil dilutes the remaining oil almost instantly... |
Don't forget there's significantly more oil left in the galleries and oilways, hydraulic tappets etc.
So if you still need to undo the bloody big metal undertray and take the sump plug out , you might as well stick it on a ramp and do the whole job by draining.! |
| zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 258
I did an oil change yesterday with my new vac pump, so easy to use.
| caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1176
In that case the suck-out method is the way to do it and save the £10 new sump bolt price also. |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
You need one with a minimum tank capacity of 10 litres to guarantee no spillage.
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442
Thanks to Mike I also have the 10L Draper it is brilliant and would never be without it now. 2018 SE SDV8 4.4 Byron Blue |
| All times are GMT |
