![]() | Home > Maintenance & Mods (L405) > L405 oil change |
| caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1176
Thanks Mike. |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3963
I need to get on with this, got the suction pump, got the oil and will warm the engine by going to collect the filter. Where do I insert the probe? Geoff |
| zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 258
There is a dedicated tube next to the oil filter cap, it twists and pulls up.
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863
use the vac pump units....can do oil changes in this rig in a tux. Main reason I bought 2 of them..........L405's , not vac pumps |
Ah well took me a while to do the oil change, pump didn't have 9mm straw and of course the 6mm OD ones don't fit, also instructions were missing. Have raised the issue with supplier.
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
Geoff,
Thanks Mike, that's the tube that was missing. I think a workaround would be simply to buy some 6mm ID tube and connect it to the other 6mm OD "straws". What about lever positions on top it all seemed to take me ages. Geoff |
my extractor has a few diff sized tubes but it also comes with a black rubber grommet to put on the end. The rubber grommet slides over the oil pipe inside the oil cap reservoir and creates an air tight seal. Sometimes too well and I need to really get a good grip to pull it off 2014 FF Autobiography 5.0 SC
| All times are GMT |
