|  | Home > Technical (L322) > 2008 L322 HSE Not starting |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2309      | Did you ever fix this I have a similar issue starts second time round every time with the same code Current stable:
|  29th May 2022 3:52pm |
| DanPoole Member Since: 01 Mar 2017 Location: Kent Posts: 60      | Hi,
|  31st Jul 2022 5:18pm |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2309      | Fuel system related failed non return valve on pump was letting the fuel from the line seep back in but cranking a couple of times filled the line up Current stable:
|  31st Jul 2022 7:15pm |
| DanPoole Member Since: 01 Mar 2017 Location: Kent Posts: 60      | Appreciate the reply, Dan!
|  31st Jul 2022 7:20pm |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2309      | To be honest different engine I know but I was lucky enough to have been donated a spare fuel pump (used but working) so I did it myself time consuming but not costly Current stable:
|  31st Jul 2022 8:40pm |
| Posting Rules
 comfort relay-mechanical failure-actuator is stuck closed.
