Home > Technical (L322) > 2010 vogue tdv8 aircon
Landyandy1765
United Kingdom 2010 Range Rover Vogue SE TDV8 Baltic Blue
Hi
I have a 2010 vogue tdv8 and the air con works fine while driving along but in traffic it starts to blow warm .
I've removed the grill today to check the electric fan but can't see one I can only see the viscous fan . This works.
Cars I've owned in the past have had electric fans in front of the condenser is this not the case with the vogue.
Thanks
Andy
Post #638479 2nd Aug 2022 10:09am
DrRob
4.4 TDV8? If yes, I'd bet the valve in the air con compressor if shot. Fit a new compressor. Seen it lots of times including my own motor. Site sponsor Glenrands have done loads and have loan cars Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638493 2nd Aug 2022 1:06pm
Landyandy1765
Does it have a fan fitted for the Aircon normally.
If I drive normally its as cold as you like just when I stow down in traffic . Like the condenser isn't cold enough
Post #638495 2nd Aug 2022 1:38pm
mjdronfield
As above….. What engine is it? 4.4 has a known issue, 3.6 doesn’t….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #638500 2nd Aug 2022 3:14pm
Landyandy1765
4.4 tdv8 2010.
Post #638538 2nd Aug 2022 8:16pm
mjdronfield
There is a known issue with the RCV valve on the air con compressor. It makes it do all sorts of strange things, with a few different symptoms.
https://www.fullfatrr.com/forum/topic43778...ed+air+con
Its a bit hit and Miss how it behaves.
Would be my first thing to investigate.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #638540 2nd Aug 2022 8:24pm
Landyandy1765
But does this year range rover have a secondary fan fir the Aircon. As the zircon works fine when driving . Only plays up in traffic
Andy
Post #638542 2nd Aug 2022 8:30pm
mjdronfield
Not sure…can’t see it on the diagrams.
The Workshop Manual is in the Wiki for download.
More knowledgeable AC folk will be along soon…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #638546 2nd Aug 2022 9:27pm
Phoenix
Andy
It's a PWM controlled viscous coupling, I've had issues with these over the years - not a common failure but one that can affect the aircon.
First check - can you hear the fan 'roar' slightly within a minute of starting the engine from cold? (i.e. does it achieve 100% lockup - one of the self tests the ECM does if not run for a while).
Second check - if you have diagnostics, can you read the fan speed, and does it vary with engine speed / aircon load?
There is no secondary electric fan on a UK / EU specification vehicle.
Post #638551 2nd Aug 2022 10:21pm
Landyandy1765
I'll check the fan speed today. I can hear the fan spinning from time to time. Should it vary with the air con switched on
Post #638559 3rd Aug 2022 4:05am
Phoenix
Dependent upon load, yes - also check the reading from the refrigerant pressure sensor if you can. Have you had the refrigerant charge weight (not pressure!) checked?
Post #638560 3rd Aug 2022 7:10am
Landyandy1765
No never had the gas checked at all .
As it worked above idle.
Post #638563 3rd Aug 2022 8:09am
garyRR
Andy
I had exactly the same issue as you. Fine on the move but no air con in traffic. A bootfull over 2,000 rpm for a few seconds and it would come back in 30-60s.
As others are telling you, it's the known issue with the Refrigerant Control Valve on the air con compressor. The compressor has to be removed to replace it and as these are now over 10 years old, it's best to replace the entire compressor.
The cause of your issue isn't going to be anything else so, just a warning before spending money and/or time on fan couplings, re-gassing etc.
Expect to pay £800-£1,000 for a garage to supply and fit a new one and re-gas or if you're handy, here's the DIY guide I wrote:
https://www.fullfatrr.com/forum/post635799.html#635799 2015 Range Rover Autobiography 4.4 SDV8
Post #638566 3rd Aug 2022 8:42am
Landyandy1765
Hi .
I've plugged in this morning and only can see fan pulse not speed.
I can hear the fan over the engine noise.
To do the job myself what's the cost of a compressor . I can get re gasses locally.
Post #638569 3rd Aug 2022 9:23am
garyRR
£290 for a compressor from Maltings Offroad or Advanced Factors.
Vacuuming of the gas i got done for free.
Pressure test and re-gas is about £50-80. I got mine pressure tested and recharged by Kwikfit for £60 on a pre-booked appointment.
Otherwise, no other costs if you have the tools. 2015 Range Rover Autobiography 4.4 SDV8
Post #638571 3rd Aug 2022 9:28am
