![]() | Home > Technical (L322) > FBH Questions - 2011 4.4 TDV8 - Remote Not Pairing |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
Off the top of my head, I can't remember the fuse number....but, if you search under FBH there's loads of info on there about it.
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Hi Garry
For testing, either use the Webasto software and a suitable jumper harness or disconnect the external temperature sensor, the default value is -40deg. C. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
@Phoenix - external temperature sensor would be the one behind the front grille? 2015 Range Rover Autobiography 4.4 SDV8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Thanks!
So, the temperature dropped below 16 degrees today for about the first time. I turned on manual heat from the infotainment system and hey presto, came back to a nice warm car and a slight smell / visible exhaust vapour from the front left wheel so, all seems to be working!
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
The remote paring procedure is in the Wiki workshop manual under
Richycsurfer Member Since: 18 Nov 2018 Location: Plymouth Posts: 44 ![]() ![]() ![]() |
Do all late L322 have the FBH? I had a '55 reg TD6 with it but unsure if my new ('11) L322 will when it arrives. |
Thanks, found it.
I have now tried the remote learn procedure umpteen times and all I get is the flashing red light on the remote.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
Fob Battery? Mine did this when the battery level went to 2.8V - it needs a full 3.0 |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
My experience, a bit of time ago, was the pairing process didn’t work. IIRC the procedure I used was to disconnect the receiver unit beside the rear fuse panel from power. Then , holding the remote button depressed I reconnected the receiver unit to power.
I have one on order. Good job of Webasto to go and use batteries which aren't and have never been readily available! I did try removing the plug from the Telestart unit but not plugging back in whilst holding the button. Will try that tomorrow. Otherwise next step is to wait for the battery to arrive. If the telestart unit has failed, I may do a DIY job because I can link a WiFi switch to Alexa... who I can then shout at 5 times until she listens to me to warm up the car. 2015 Range Rover Autobiography 4.4 SDV8 |
