![]() | Home > Technical (L322) > Park assist module |
| bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344
Should be on the left hand side of the boot as you look at the car from the rear.
| DEEBEE(060) Member Since: 18 Jun 2022 Location: Georgia Posts: 43
Thanks, found it. Now to investigate whether it is the module or more likely a sensor. |
| chdavis Member Since: 29 Nov 2021 Location: Washington DC Posts: 46
If the button doesn't light up when you put the car in reverse, or it is delayed, you have yourself a bad module. If you get the long beeps when the PDC engages, you probably have a sensor issue. 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
