![]() | Home > Technical (L322) > Boost pressure actuator Bank1 and Bank2 4.4TDV8 |
| ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187
I may be chasing a problem that doesn't exist, but would be good to know what they mean. The engine runs ok though. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
| Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 283
I've been wondering the same thing. The controller output seems to bounce around considerably, as if the boost actuator is sticking or is slow to respond. |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
That's a sticking actuator, there is a strategy in the programming that tries an 'unstick' - which seems to be working for now, I'd investigate further before it becomes an inconvenient problem. |
Thanks for that, question is which one?
Whichever one you're measuring, which appears to be bank 1 from the graph labels- from another resource
Checking the rose joints of both would be a good diagnostic & preventative maintenance first step. |
Rose joints on these?
Yep, like this
Thanks. I suspected the VGT but will look into all of them. This would explain the sluggish behaviour (at times)
It very much depends on how the software is written, with Ford based stuff, I would expect bank0 and bank1, however, with aftermarket diagnostics sometimes this is translated to 1 & 2. The only way to be 100% certain is to disconnect one (the easiest one to get to!) and see which values are affected, don't go by DTC alone as they could well have been transferred verbatim. |
Is that the actuator in question or is it the CSOV shown in the previous diagram? |
That's just an example, it's possible of course (although less likely) that the control ring is sticking but you won't know that until you check the link rods and rose joints. |
Probably need to be clear which part we are talking about before school gearing it could be smaller parts relating to it. |
Haven't had a chance to look at it, but how many actuators are in the distribution path? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
One per turbo plus the vacuum operated deactivation - but that is not relevant to the operation of the VGT's.
| All times are GMT |
