Home > Technical (L322) > Rain Sensor and new aftermarket screen
Page 1 of 5 12345>
Googs
Australia
I have read that a non genuine front screen can cause the auto wipers not to work?
I had a non Gen screen fitted a few months ago and have tried everything to get the wipers to work with the rain sensor (no joy)
I have a quality scan tool which tells me the sensor and all connectors are ok, i also purchased All Comms from (Storey)
this also says everything involved with the screen and rain sensor are ok, is there something i missed?
Every part of the wipers and washers work no problem at all, just no rain sensor! if its on the RR i would like to use it.
I read owners manual, it says the 1st position on the wiper stork is the Auto position?
Any information will be greatly appreciated...great forum. Thumbs Up
Post #638808 6th Aug 2022 3:08am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Its not unknown, prepare yourself for a bit of a saga.
https://www.fullfatrr.com/forum/topic29972.html? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #638810 6th Aug 2022 5:45am
garyRR
Yep, happened to me on my last car.
A non-Pilkington screen and the sensor for the lights and wipers never worked properly. Sometimes the wipers operated at random or not at all and the headlights sometimes turned on, sometimes didn't and sometimes turned off. But, if I set either to manual, they worked fine.
Came up with the error on IID over screen thickness. Calibration of the sensor did nothing and a new sensor also did nothing. 2015 Range Rover Autobiography 4.4 SDV8
Post #638823 6th Aug 2022 9:26am
p38arover
Australia
It happened with mine, too. Diagnostics indicated the sensor was faulty so I bought another off eBay. While I was waiting for it, I read in the Faultmate help files that it might need a recalibration, so I did that and it worked.
I didn’t use the sensor I bought. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #638825 6th Aug 2022 9:40am
Slow progress
I may be in the same boat, Autoglass are turning up today and I’ll be asking them to make sure it works, as they don’t have a Pilkington screen in stock and I need the car back for Monday as I’m off to a wedding!
Will see how we get on. L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #638843 6th Aug 2022 1:43pm
Slow progress
Sensor appears to work. Autoglass techs said they’ve had it before with bad batches of glass being slightly too thick or thin throwing sensors off. His advice to me was to get the hose out tomorrow after the sealant has gone off and spray it with a fine spray and gradually move closer to make sure it comes on not just when it’s drenched as they can sometimes affect sensitivity of the sensor.
He did say they’d not had an issue for a while, but some of their warehouses take a while to cycle through old stocks depending on demand. L322 TD6 2003
Post #638846 6th Aug 2022 2:21pm
Googs
Australia
Good read, thanks for sharing that. its 5am at moment as soon as it becomes light i will get the garden hose out for testing again! Censored
Post #638872 6th Aug 2022 8:09pm
Googs
Australia
I have use two different scan tools, neither tool mentioned anything about glass being too thick or the the rain sensor has an Auto light sensor in it...
I will get the Launch 431X Pros out again and check for recalibration on the program.
Post #638874 6th Aug 2022 8:16pm
Googs
Australia
Back again, has any of you used the All Comms to recalibrate the windscreen sensor ? if so could you share your expertise.
I appreciate any assistance you can offer.
Post #638969 7th Aug 2022 9:26pm
Googs
Australia
Thx SP, Would a spray bottle with water used to test the sensor work?
Post #638970 7th Aug 2022 9:30pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
We have two L322 fatty's, both 2010 and both have had new screens within the last 3 months (bullseyed both of them, virtually in the same place as well). Anyway, Autoglass replaced both screens, on one the auto wipers work fine and on the other they have reverted to adjustable intermittent wipe, odd. Have reported to Autoglass and it's been referred to their warranty dept. so we'll see what happens. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #638986 8th Aug 2022 9:10am
Googs
Australia
That's bloody bad luck with the screens mate.
Sounds exactly the same as what's happened to my RR, it starts at 0 then intermittent (variable) and then 2nd speed and then full, oh and before 0 push down and it does one wipe,, does that sound right?
The sensor doesn't operate in any position.
Post #638999 8th Aug 2022 10:17am
GraemeS
Australia
I pulled the fuse for the rain sensor to convert them to intermittent.
Post #639000 8th Aug 2022 10:20am
Googs
Australia
G’day Graeme, is the rain sensor and the intermittent in the same position, what I mean is if you RR is set to rain sensor and you pulled the fuse did you move the wiper stork to another position? 😎🇦🇺
Post #639005 8th Aug 2022 10:45am
GraemeS
Australia
Intermittent uses the same position as auto but the rotational settings change the intermittent delay rather than sensitivity.
Post #639021 8th Aug 2022 1:13pm
Page 1 of 5 12345>
