Home > Technical (L322) > How much oil on oil change!
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Just changed the oil cooler and removed the oil before hand with a draper vacuum pump before hand. I was shocked how much oil was removed - nigh on 10 litres according to the draper graduations. Anyway, on refilling it took a full 10 litres and wasn't actually full to the top mark - 2 graduations short. Does this seen right? Anyone else had similar experiences?
Regards
Mark
Post #638889 7th Aug 2022 5:10am
Baltic Blue
That sounds too much to me.
I usually get 9.25 litres of dirty oil out, but when I am refilling it I start with 8 litres then add very small amounts (less than 0.25l ) at a time until I am happy and it shows one section from full, then when it gets hot it shows full.
Post #638892 7th Aug 2022 7:41am
JayGee
I get 10L out when the engine is cold and the oil has fully drained down through the engine overnight. Takes longer to extract cold oil though. 2012 TDV8 Vogue (L322)
Post #638894 7th Aug 2022 8:31am
garyRR
Re: How much oil on oil change!
Regards
Mark
Sounds about right to me.
Removing the cooler will have removed a small vacuum inside the block and allowed some additional oil to reach the sump.
When I do a change on warm, I get around 9 litres out anyway and that's only leaving it to drain for a short while. Total official capacity is 9.9L.
As your oil is now within the fill range, leave it there, drive it for a day and take 2 separate readings tomorrow 20 minutes after using. Obviously ensure the car is level.
 2015 Range Rover Autobiography 4.4 SDV8
Post #638906 7th Aug 2022 11:13am
nambFFRR
I’m on the same page as you in this. The draper vacuum took out nigh on 10litres so I’ll keep my eye on it. I started with 8litres and it was on the bottom mark and saying top up. I did a litre at a time and in the end added the final 0.5litre and it’s just short of the top max mark. Just takes ages to check the level as we all know!
Thanks again for the answers
Regards
Mark
Post #638912 7th Aug 2022 12:33pm
DrRob
If it’s on max when cold, it will show overfilled when checking warm 20mins after shut down.
I start at 8 then top up so it’s 2 notches above middle level when cold. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638957 7th Aug 2022 6:55pm
Phoenix
What you take out is immaterial, especially on DPF equipped vehicles - any work on the oil cooler will release additional oil back to sump, not a massive amount, but 'some'. A dealer service fill will be 9.4 litres, no messing around with checking levels, a little bit at a time etc. etc. these boys are on the clock so are not going to waste time when they know that 9.4 litres will put the oil level indicator around the 3/4 full mark - which is where it should be.
Also bear in mind that the sump is designed to allow the vehicle to operate at extreme angles for extended periods of time, not having the optimum oil level isn't going to cause any problems when it's predominantly used on tarmac.
Post #638966 7th Aug 2022 9:10pm
Googs
Australia
Is It best to check the oil when hot or cold? asking for a friend Rolling with laughter
Post #639511 13th Aug 2022 8:17pm
Phoenix
Yes.
Tepid will only give you intermediate results.
Post #639512 13th Aug 2022 8:19pm
Googs
Australia
Thx Phoenix. Thumbs Up
Post #639516 13th Aug 2022 8:38pm
JayGee
Why not check the oil as per advised in the owners manual?
On a level surface with engine at operating temp and 15 mins after shutdown. 2012 TDV8 Vogue (L322)
Post #639518 13th Aug 2022 8:51pm
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
I found this "cheat" previously for Jaguar - will try it tomorrow see if it work on FFRR
It will show the oil level without waiting 10 minutes - makes it so much easier to do oil and filter
Once it warm obviously make sure level is correct after running
1. Open the Bonnet
2. Turn on ignition without starting.
3. Scroll through settings on dash
4. Select oil level
If read out is not available, push the "Cancel" button on cruise control two times quickly and try again. 2009 - L322 5.0 S/C Autobiography
Post #639519 13th Aug 2022 9:08pm
JayGee
That procedure does work. 2012 TDV8 Vogue (L322)
Post #639537 14th Aug 2022 7:52am
Phoenix
It does on a Discovery 4, may well on a L405 but definitely not on a L322 <2009
Post #639542 14th Aug 2022 8:52am
Sonearly
It only works on L332 if you have the bonnet open
Post #639544 14th Aug 2022 8:59am
