![]() | Home > Maintenance & Mods (L322) > Clunk noise when turning Steering left or right? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1405 ![]() ![]() |
Change the anti roll bar drop links, they are cheap and easy enough to do... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
That could be anything....
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
I’ve changed the anti roll bar bushes and link bars as suggested and agree that I have to find a good Independent. Just surprised that the garages I have used can’t answer it? Perhaps they didn’t look for sub frame bushes etc but it does handle well. I do have an Independent not so far away but he is known to be a bit of a rip off merchant.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
The odd noise now and again over 4 years and the garage can’t find anything wrong - forget about it |
You are not far from our own Cam Tech Craig, he's between Bristol and Gloucester... |
Thanks for the replies guys.
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
Have you tried a wheel alignment? I had a clunk / knock from the rear right. Had it realigned after replacing the rear diff seal and the noise was gone! |
Thanks vs322.
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 101 ![]() ![]() ![]() |
Good morning guys, we had exactly the same symptoms on the RR we "borrowed" for a year, it came with the knocking and I did most of the things mentioned above but still couldn't find it, then one day when the car went in for its MOT, the tester "found" the fault. It was a loose bolt on the steering rack, a quick tighten up and, noise gone!!
Yes, it can indeed be something as simple as a loose nut. I thought it was the rear subframe bushes in my case. Glad it wasn't.
Thanks guys points on my list to check, that would be a great solution! |
Hi anyone,
