Home > Maintenance & Mods (L405) > Can someone help
Bluebird
Wales 2016 Range Rover Autobiography SDV8 Santorini Black
Can someone help
Just had a warning- SOS system limited functionality. Can anybody explain what it means, and is it an expensive job and finally covered by LandRover warranty. Due to oil dilution only use once a week with 30 min journeys going at in excess of 40 miles an hour.
Post #638916 7th Aug 2022 12:47pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
I think it relates the the SOS button overhead and the related subscription service you can get for it. I believe it has its own small battery pack that can fail over time and needs to be replaced to make the system function again. I believe the battery pack is expensive for what it is and as it’s a battery I don’t think it would be covered under warranty but I’m happy to be corrected! FFRR SDV8 Autobiography
Post #638917 7th Aug 2022 1:14pm
Bluebird
Thanks James.
Post #638921 7th Aug 2022 1:27pm
Kot
Did you sort this?
It could be a Telematics Control module fault
do you have an OBD2 device that can read your fault codes and able to reset them?
If not the Autel AP200 (bluetooth) is a cheap buy will read and clear codes.
See this url showing what fault codes give the alarm you have.
https://www.jlridssddmongoose.com/diagnost...odule-tcu/ 2018 SE SDV8 4.4 Byron Blue
Post #639308 11th Aug 2022 4:52pm
Bluebird
I went on a journey yesterday and it did not show. I don’t have the tool quoted and will consider buying. I have a service due in September so will keep an eye on it till then. Thanks again.
Post #639311 11th Aug 2022 5:02pm
