Home > Technical (L322) > Pitman puller not working for me.....
Chrali
Thought the pitman puller would work for me, so its really the wrong time to find out my hammers are too wimpy. It was going so well as I'd got all the nuts undone ok. Sad
 Encourage alternative fuels, use all the petrol!
2012 Range Rover Vogue 4.4 TDV8
2006 Mercedes GL420 CDI
2006 Porsche Cayenne Turbo S
2006 Jeep Commander 3.0 CDI with GDE HOT Tune
1997 Nissan Patrol 4.2 GRSE
1995 Vauxhall Monterey Diamond 3.2 v6
1994 Range Rover 4.2 LSE Beluga Black, Softdash, Brooklands Body Kit - Loved it!
1993 Range Rover 4.2 LSE ended up converted to 300tdi
Post #639067 8th Aug 2022 9:32pm
Googs
Australia
To be easier on you and your tools you will need this sort of tool for a less painful extraction and also you will need a BFH or a big hammer.
https://www.supercheapauto.com.au/p/toolpr...lsrc=aw.ds
Post #639070 8th Aug 2022 9:48pm
Chrali
That#'s a little splitter isn't it? Encourage alternative fuels, use all the petrol!
Post #639071 8th Aug 2022 9:50pm
Googs
Australia
I suppose cause we live in different parts of the world it could be called that, but here in Aus we call em a tie rod puller/separator. so yes
https://www.ebay.com.au/itm/190841137157?c...gIQAvD_BwE
Post #639072 8th Aug 2022 9:56pm
Chrali
Sorry what I mean, is do I need a 35mm or a 45mm?
BFH 4lb hammer and 35mm splitter ordered!
https://www.amazon.co.uk/Laser-5497-Large-...amp;sr=8-6 Encourage alternative fuels, use all the petrol!
Post #639073 8th Aug 2022 9:59pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Re: Pitman puller not working for me.....
Chrali wrote:
Maybe it's the photo but isn't this tool on the wrong way? Shouldn't the bolt bear onto the thread of the ball joint you are trying to split?
Post #639078 8th Aug 2022 10:40pm
Chrali
Kezbo1981 Oh I think you are right ! I wasn't happy with how it was going, so I'll defo try it the other way around. Encourage alternative fuels, use all the petrol!
Post #639080 8th Aug 2022 11:11pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
the way I do mine is to slide a big bar in on the side pick up on something and get someone to stand on the bar that is
sticking out put the nut on 3/4 turns so when she does go it's not going to drop right out and give it a good hit with a good sized hammer pressure and shock hit it has got no mother or father to whurry about she will go looks like you have put a good amount of lube on. I always use diesel when I have a tight one seems to soak right in new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #639091 9th Aug 2022 11:24am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Alternatively if you cant get the tool in, undo the bolt holding the arm to the subframe and let the arm dangle.
Using a large at least 2lb hammer, hit it on the casting between the thread and rubber boot hard. It’ll drop out after few good whacks. You can also screw the nut back on a couple of turns so if you miss it doesn’t damage the threads, but if your changing it anyway???
Post #639093 9th Aug 2022 11:47am
Chrali
Cheers guys,
Oggy I don't have a big bar to give that a go, so just awaiting Amazon to deliver my BFH and whack seven bells out of it; ike diesel daves suggestion.
I need the car this weekend, so I shouldn't have started Sad I really need a cheap daily car. Encourage alternative fuels, use all the petrol!
Post #639139 9th Aug 2022 10:42pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
the puller is on wrong Shocked 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #639168 10th Aug 2022 11:21am
oggy
morning chrali i think that might be best the splitter will do the job I would still give that casting a good whack before putting in the splitter. and make sure you put some copper slip on new joint easier next time round new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #639170 10th Aug 2022 11:57am
Chrali
Cheers for your help guys, but sorry to say the splitter didn't seem wide enough to do the job Big Cry Seeing as SWMBO had some hospital appointments over the next few days I had to just connect everything up and I'll get the garage to do it before the MOT this week (least I won't get stung on parts).
Yes the pitman puller was on upside down, as I couldn't see how well it could fit on the right way up. Encourage alternative fuels, use all the petrol!
Post #639756 15th Aug 2022 11:25pm
