![]() | Home > Maintenance & Mods (L322) > Side Steps - Captive nuts gone... |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 397 ![]() ![]() ![]() |
Hi all,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8637 ![]() ![]() ![]() |
A couple of ideas, I expect you will get a few more....
Thanks Pete - Yes, I had considered welding a plate in as a last resort but its a bit drastic. Good point about the Ali Rivnuts - I'll look to order some |
If you try to clamp through both sides of the box section sill I think that might just keep bending both sides in, maybe a larger hole in the outer sill and a smaller one in the inner sill and use the large hole to put a bolt, with a decent size washer through the smaller hole which you can then secure with a socket and extension through the large hole.... if that makes sense... You could plug the large hole afterwards if needed.... Pete
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6422 ![]() ![]() |
Can't remember if it was the front or rear captive nuts that went on me when removing the side steps, but there was a big hole in the rail nearby. I was able to get a nut and washer over the hole and then run a bolt up. Just enough room to get a spanner IIRC. It eventually had enough grip to self tighten without a spanner. Not ideal, but a quick fix. .
I went for a mixture of that and my finger stuffed up in the hole - its all done now and I'm about to post it all up on my main thread.
