Home > Technical (L405) > FBH Not working no faults IID tool
fenair
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Good afternoon, 4.4SDV8 2015 VSE Yesterday 0 degrees the car took an age to warm up, so today i scanned it with the IId tool, i have no faults, start the car and no activity from the FBH , currently 2 deg C so should kick in under 6 if my disco is anything to go by.
On my D3 & D4 sdv6 using IID trool you could activate teh FBH in service / test section on IID tool , butr there is no listing on the RR?
Build sheet says
Suplimentary heating Fuel burning
Block heater Less
In the CCF file FBH down as being present, i changed the CCF to timed climate and this brought up the tab in the touch screen on the dash, activated manual heat and the system goes through the sequence but blows cold air, no FBH running, set a timed climate and it all goes through and blows cold air, with teh engine running the FBH does not kick in its stone cold after 5 minutes with only tepid waterr pipe temp from the engine, yesterday i left malham yorkshire and got to full engine temp after 7 miles as the roads were litterd with fallen trees debris and ice so i hardly got more than 1200 rpm, this cant be good for the motor and aint too cracky inside either, reminded me of a escort diesel van i had 25 years ago.. Laughing
Any ideas peeps, as im lost without being able to run it via IID plus no error messages all seems strange to me, my D3 would lock out on low fuel, but you could clear it using iid and prime the FBH , but i can not see it in any menues... advice welcomed.
Pat
 SDV8 2015
Post #614011 28th Nov 2021 1:58pm
deansmith
United Kingdom 2016 Range Rover Vogue SE SDV8 Carpathian Grey
My 2016 VSE is suffering the same issue (seems like we're not the only ones judging by recent threads), I'll be interested to see how you get on. Have you checked the fuses?
Post #614098 29th Nov 2021 8:03am
fenair
Yes it will... seems that there are not too many responses either so looking like a lack of interogation by gap iid tool as LR must have the ability to prime the pump etc via diagnostic control, which i suspect is the issue, as its likley flamed out at some time and the iid tool cant see the fault... all seems very strange.. SDV8 2015
Post #614099 29th Nov 2021 8:39am
Kavli
Sweden 2013 Range Rover Autobiography SDV8 Causeway Grey
I had the same issue when I bought my L405. The FBH would not start, neither on manual nor remote. The IID-Tool showed absolutely nothing.
But I had an iCarSoft LRII diag unit that could show me live values for telestart, fuel and coolant flow pumps, etc. It could also pull the code for a broken glow plug. It was the welding of the feeder wire that had broken. After re-welding it and clearing codes it worked again.
I'll go as far as to call the IID-Tool totally worthless regarding the L405.
-- R
Post #639141 9th Aug 2022 11:30pm
fenair
Thanks for this, yes I agree te GAP tool seems very limited almost to a Ebay code reader standard as you say there is something not right , hence why the FBH wont run but nothing showing on the reader, The workshop next to mine has a decent diagnostic set up so i may borrow that and see if it picks anything up.
Speak soon
Regards
Pat SDV8 2015
Post #639150 10th Aug 2022 7:03am
