Home > Technical (L322) > Cabin temperature sensing fan noisy - can I lubricate it? |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 |
Have you unplugged the dash section with the controls and have the little fan out of the equation? if the main heater fan has noisy bearing it would suggest it due for new bearings. Someone else will chime in to help you out. |
10th Aug 2022 1:30am |
This normally gets the Post moving as you have had 63 look at the post and 1 reply. |
10th Aug 2022 1:33am |
h18ant Member Since: 07 Jul 2022 Location: East Sussex Posts: 14 |
Hi, yes, I have unplugged all of the controls and I have isolated the noise to the little fan. I just don't know if I can disassemble the fan and try and lubricate it perhaps, or replace it. |
10th Aug 2022 6:36am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
You could try spraying the fan with wd40 and see if it improves things. If so you could then spray it with a light lubricating oil. The one thing you have to avoid is covering the fan assembly in oil as it will then collect dust in use. |
10th Aug 2022 7:40am |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 92 |
Been looking at lubricant sprays for another reason and note that WD40 do a PTFE dry lubricating spray this may help you with the fan as it wont leave a sticky mess to attract more dust etc but should sort the bearing
10th Aug 2022 8:01am |
Thanks for the suggestion, I might give this a try! |
10th Aug 2022 12:28pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
i have started using this discofish on my Winchester sx3 10 shot semi-auto and is a nice drop of stuff I tried it from the reviews being number 1 in the top ten new vehicle purchase
10th Aug 2022 12:54pm |
h18ant, glad to see you have a couple of good problem solving diagnosis.
10th Aug 2022 9:55pm |
gotters Member Since: 15 Aug 2015 Location: London Posts: 41 |
i got a can of that PTFE spray on the recommendation here as mine makes a slight fan/buzzing noise when the heater first runs in the winter (but not the cold AC in the summer)
15th Aug 2022 12:50pm |
gotters,
15th Aug 2022 9:05pm |
thanks for the reply, by dash assembly do you mean the whole dashboard - in other words start removing the driver/passenger vents, the speaker grill then unscrew the whole thing to get at the HVAC system innards ? |
16th Aug 2022 4:33pm |
Nah just the section, if that isn't possible you will have to spray through the vent hole as explained before. On my L322 i can remove the small front section without taking the dash apart. |
16th Aug 2022 8:37pm |
So I've been playing around with the RR today....should have been fixing the rain sensor though. I decided to attempt to fix the noisy cabin temp sensor fan instead, here is some of the photo's i gathered.
17th Aug 2022 7:28am |
