Home > Maintenance & Mods (L322) > Offside sidestep removal |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2982 |
You can remove the air tank very easily. It's only 3 bolts and you don't need to disconnect the air line.
10th Aug 2022 2:47pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
You might find if you hammer the brackets upwards they will move far enough to let the bolt heads pop out through the holes.
10th Aug 2022 5:26pm |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 374 |
I've just reinstalled my steps and used a very thin 10mm ratchet spanner up there by the air tanks. Took a little time - I wasn't aware the air tank came off without needing to unplug any lines so that's good info Dave Gavin
10th Aug 2022 5:43pm |
tpeat12 Member Since: 18 May 2020 Location: Glasgow Posts: 69 |
Thanks for the suggestions Gents. I’ll take another look at the weekend.
10th Aug 2022 10:02pm |
Ended up undoing the 12 mm bolts and going to town with a hammer.
11th Aug 2022 7:57pm |
