![]() | Home > My Range Rover > Absolutely Gutted |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 46 ![]() ![]() ![]() |
My uncle used to say that it´s quite ok to engine make some noise, it´s when the noise stops, you´re |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442 ![]() ![]() |
If you do want to do your own investigations, I would first change the oil and filter now, and send a sample away of the old oil for analysis who knows what other things are developing internally. As blow by, from bad rings will gunk up and certainly breakdown the oil you already have. Look at the filter in this thread page 5 https://www.fullfatrr.com/forum/topic63193-165.html Also https://www.fullfatrr.com/forum/topic62361...e+breather Lots of good comments about breathers and separators being blocked to investigate as well Good luck 2018 SE SDV8 4.4 Byron Blue |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
Video clip of the noise etc , you can here a tapping that doesn’t seem to be in time with the engine what’s everyone’s thoughts
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
have they carried out a full diagnoses IE compression test on every cylinder?
Not sure what has been done but on driving it the other day just before I took the video it drove sweet no hesitation no smoke from what I could see 2012 Range Rover Westminster 4.4 TDV8
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 397 ![]() ![]() ![]() |
the vid link is not working states private vid you may have to open it up to the big wide world new vehicle purchase
Hopefully this works
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3396 ![]() ![]() ![]() |
Difficult to reconcile your Indy’s diagnosis of ‘catastrophic failure’ with it driving smoothly with no smoke. All you will hear removing the filler will be the cam lifters. A faulty hydraulic lifter will make a loud tapping sound but never heard one on more modern cars. Is your Indy a LR specialist? 2012 TDV8 Vogue (L322) |
Was that video just after startup? If so I would expect water vapour and blow by gases getting into the crank case / cam covers. 2012 TDV8 Vogue (L322) |
They are a landrover specialist and the bid was after a 20 min drive inc a bit of heavy foot 2012 Range Rover Westminster 4.4 TDV8
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
If it’s still running and it’s not smoking etc, I’d get a second opinion. |
Think I’m going to do that, turns out my son watched the video and he said it’s been ticking on start up like that for months but as I rarely open the window I can’t hear it, can was sat for three weeks due to holiday I’m thinking after some research could it be hydronic lifters sticking, could someone take a video of the same engine and open the oil cap
i will fire mine up later 2012 TDV8 4.4 and do the same see what it is like.
Thanks for offering to do the vid it would be a great help I’m leaning towards lifters 2012 Range Rover Westminster 4.4 TDV8
