![]() | Home > Technical (L322) > Faults |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 957 ![]() ![]() |
Suggest starting by checking the battery voltage / output which if low, can trigger random fault codes |
KyleP Member Since: 24 May 2022 Location: North Carolina Posts: 3 ![]() ![]() ![]() |
I plan to get a new battery tomorrow. What cold cranking amps do you suggest? |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 568 ![]() ![]() ![]() |
019 AGM battery. Drives:
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 164 ![]() ![]() ![]() |
On top of fitting a new battery...
A new wheel speed sensor cured the problem. |
