Home > Technical (L322) > B1311-96 Clock Module - Fault Code
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
My recent purchase - 5.0 S/C Autobiography
JUST ONE CODE !!!!!
B1311-96 - Clock Module
Have searched the Wiki and previous posts but no definitive answer
Anyone have a clue ?
Thanks
Dave
p.s Google has loads with same code but no real answer
 2009 - L322 5.0 S/C Autobiography
Post #639424 12th Aug 2022 4:46pm
Googs
Australia
That looks like a page from a LAUNCH code reader is that correct?
Post #639508 13th Aug 2022 8:10pm
RS2000CUSTOM
Certainly is
Post #639509 13th Aug 2022 8:14pm
Phoenix
Does the clock work? if so, clear the DTC and investigate if the clock ceases to work or the DTC comes back. This relates to the analogue clock, not the actual timekeeping in the BCM/GEM.
Post #639513 13th Aug 2022 8:26pm
RS2000CUSTOM
Yep I have tried to clear but the DTC remains
Analogue clock appears to keep great time and also when I initially set the correct time the analogue clock adjusted itself as expected 2009 - L322 5.0 S/C Autobiography
Post #639514 13th Aug 2022 8:30pm
RS2000CUSTOM
So "Clock Module" is just the analogue clock ?
If so I can live with that as my only DTC
Plus it tells the correct time - so best left alone !
Thanks 2009 - L322 5.0 S/C Autobiography
Post #639523 13th Aug 2022 9:25pm
Phoenix
Yep, that's it. You could try a battery disconnect but the chances are that'd create more DTC's.
You could try pulling the plug on the analogue clock for a few minutes, it might help, but TBH, it's not something to worry about.
The clock has a data line from the instrument cluster (IPK) which supplies the current time, which is set on the IHU. The IPK is responsible for maintaining the 'master clock' the analogue clock is just a display, slaved off the IPK via an I-BUS connection shared with a few other modules.
Post #639525 13th Aug 2022 9:29pm
Googs
Australia
Tell me does the analogue clock keep time with the digital time on the headunit? If so what happens if you up-grade the headunit to aftermarket etc
I have noticed that the analogue clock in my RR quite often at any time of the day at start up returns to 12 bells. Is there a reason for this?
Post #639526 13th Aug 2022 9:39pm
Phoenix
The IHU is used to input the time into the IPK - its the IPK that is the time master, without any correction from the IHU, it'll just keep ticking along. I've had the analogue clock re-sync a few times, never really looked into it but I suspect it's related to voltage drop during cranking causing the I-BUS (single wire, pretty much like LIN) to drop out or possibly the IPK forces a re-sync if it detects dropped comms.
TBH, it's not high on my to-check list given I'd have to capture & decode the frames along with monitor the voltage at a couple of points once I can reproduce the concern. For the moment, I'm happy with 'fold on lock' mirrors and 'unlock on key off', both of which turned out to be possible with pretty simple hardware additions.
Post #639527 13th Aug 2022 9:52pm
Googs
Australia
[quote="RS2000CUSTOM"]
Certainly is
Just for interest sake what is the model number ?
Post #639531 14th Aug 2022 2:06am
RS2000CUSTOM
RS2000CUSTOM wrote:
Certainly is
It is a Launch X431-EuroPro 4 2009 - L322 5.0 S/C Autobiography
Post #639538 14th Aug 2022 8:25am
Googs
Australia
Very nice Scan tool ....not much that won't do. If i had more money I'd have one myself. Thumbs Up
Post #639541 14th Aug 2022 8:39am
RS2000CUSTOM
Googs wrote:
Very nice Scan tool ....not much that won't do. If i had more money I'd have one myself. :Thumbs Up:
Have tried many different scan/code readers for my "Day Job" and the Launch for me is the best for what I need it to do
I have been a self-employed mechanic for close on 20 years and it is impossible to do day to day jobs without a suitable scan tool 2009 - L322 5.0 S/C Autobiography
Post #639600 14th Aug 2022 8:27pm
Googs
Australia
So, did you find the answer to this B1311-96 - Clock Module ?
I have looked on the Launch 431XProS mini that i have, it doesn't give me a code at all just sends me to google to search ...
Post #639605 14th Aug 2022 9:31pm
RS2000CUSTOM
Well according to posts on here it is the analogue clock on the centre console
As mine is keeping correct time and alters time setting if required then I not going to do anything about it
I will be living with the code as it not causing any issues 2009 - L322 5.0 S/C Autobiography
Post #639607 14th Aug 2022 9:36pm
