![]() | Home > Maintenance & Mods (L322) > Snowfoam - am I doing something wrong? |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 ![]() ![]() ![]() |
I believed that Snowfoam was a revolutionary way of cleaning your pride and joy but I don't seem to be getting any benefit from it!
It looks good, and is fun to apply. If only it smelt good then it would be a sensory extravaganza.
So Dan it's as I thought - just a gimmick that's fun to apply but that's it! CURRENT : FFRR 2012 4.4 TDV8
No, it's absolutely not a gimmick. 10 minutes may be a bit long to be fair but what it's doing is loosening all the small dirt particles, the ones which will produce the swirls if ground into the paintwork with a sponge. The pressure washer should then remove these before you touch the surface with a wash mitt.
I wouldnt say it's a gimmick, for fear of being hunted down and killed in my sleep. Snow foam lovers get quite upset when you say things like that! ![]() |
As per mzplcg, maybe your car wasn't dirty enough!? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
Personally IMHO I think it's a gimmick.
Excuse my ignorance but was exactly is a 3 bucket wash? CURRENT : FFRR 2012 4.4 TDV8
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
2 buckets of water and car shampoo and then 1 bucket with warm water to rinse the mitt between every panel. Minimises the risk of having grit on mitt and then causing swirl/scratch marks. FFRR TD6 HSE
claud Member Since: 15 Apr 2009 Location: Godalming Posts: 103 ![]() ![]() ![]() |
Snow foam works if you use it frequently (once a week) on cars which have a small amount of dirt.
I have Autobrite super snow foam used with a pressure washer CURRENT : FFRR 2012 4.4 TDV8
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
its most certainly not a gimmick - if used correctly
+1 |
+1 autoglym rinse aid is superb! |
