Home > Technical (L322) > Rain Sensor and new aftermarket screen
Page 3 of 5 <12345>
Googs
Australia
rvbush wrote:
All done at home, only minor inconvenience is that you have to leave it for an hour or two to allow the adhesive to cure.
Please let us know if the new sensor operates the Auto wipers....or you mite have to read Chris _ read's post.
Post #639517 13th Aug 2022 8:50pm
Googs
Australia
chris_read wrote:
It’s worth a try. If not, it’s worth eliminating the possibility of it being the cause Thumbs Up
up-date, pulled drivers seat and kick panel and excess trim /gas pedal and exposed the large wiring loom that run in the sill channel and sadly enough couldn't even find a red/green wire.
Do you think that the euro RR's are different to the Aus exported one's as far as the wiring is concerned ?
You are RHD ?
Post #639603 14th Aug 2022 9:22pm
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
Does this make my Genuine NOS Range Rover screen worth a small fortune ?
I bought it from a Main Dealer for my L322 TD6 and never used it
Have had a TDV8 and now my 5.0 S/C since then !! 2009 - L322 5.0 S/C Autobiography
Post #639604 14th Aug 2022 9:28pm
Googs
Australia
I guess it does the screen will fit a wide range of vehicles, you better hang on to it just in case.
Post #639610 14th Aug 2022 10:02pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
You are RHD ?
Hi Googs
Yes, mine is RHD. I had to sift through the loom to find them. If you still have it accessible can you see where the connections are? The crimps which join the various wires together are wrapped in tape and it is only when you open it up that you see it has turned to powder.
I’d be surprised if they used different colours for Aus. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #639631 15th Aug 2022 6:43am
Googs
Australia
G’day Chris,I haven’t been able to find any wires that are coloured red with a green stripe, there is no breaks at all in any of the wiring system in the driver-side wiring loom not sure about the passenger side yet as, I haven’t pulled the seat out just pulled the carpet up to get access to the wiring loom, you’ll see a purple multi-pin connector on the second photo that was just lying in the sill channel not sure what that is? Any clue on the connector?[/img]
Post #639641 15th Aug 2022 8:59am
Googs
Australia
Post #639643 15th Aug 2022 9:03am
Googs
Australia
Post #639644 15th Aug 2022 9:06am
Googs
Australia
Sorry for the way the photos are loaded as I’m not sure how to do them …. I could only do them from the phone not the laptop.
Post #639645 15th Aug 2022 9:09am
chris_read
Hi Googs
Sorry for the delay - I’ve been out having my front upper arms and ball joints replaced (on the car, that is Laughing )
The wiring loom for mine looks the same as Sam’s in the video (his is the 4.4) and as yours is the same year as mine it should be the same. The red/green can look almost brown/green in certain light. I’ve no idea wha5bthe purple multiplug is I’m afraid.
Apologies if I have sent you on a wild goose chase….. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #639698 15th Aug 2022 1:37pm
Googs
Australia
G'day Chris, where in the loom was the broken wires (towards the engine end or near B Pillar)?
What are rain sensor and auto lights wires doing in the loom on the sill channel.....ah what the heck i will have another look in the morning Big Cry if i don't find any think i will wrap it back up an live with out them. Thumbs Up
Post #639729 15th Aug 2022 7:17pm
chris_read
Hi Googs
It’s a while since I did it but from memory it was about halfway along the door sill. I have a friend who did this fix recently so I shall ask him to join in and advise (Dave).
Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #639731 15th Aug 2022 7:29pm
Googs
Australia
Hi Chris,
Thanks mate....there doesn't seem to be any broken wires in the drivers side loom.
I noticed on the Video that Sam found three wires then a single wire facing the other way, so 4 wires to be joined together.
These wires Chris, do you think they were soldered together or just twisted together from factory?
Post #639739 15th Aug 2022 8:58pm
Phoenix
Not many wires are soldered on vehicles, most in-line joints are electrically fused or crimped then capped with adhesive lined heatshrink. Soldering tends to be for high-current cable lugs where there is little chance of capillary action and resultant strand fracturing.
Post #639744 15th Aug 2022 9:40pm
Googs
Australia
Up-date; I've been through the wiring loom 5 times with no luck to find a green/red wire so I'm guessing there isn't any.
I'm going to put the RR back together and start a new search at the screen/rain sensor. Question
Post #639758 16th Aug 2022 12:39am
Page 3 of 5 <12345>
