Home > Maintenance & Mods (L322) > Air Con - Diagnosis...
Superspoons
After having my Air Con 'tested' and refilled by Kwik Fit a month ago, it recently started to blow out hot air again. So I booked it in with my local Air Con Specialist. He has had a look - there was some dye in the system. After plugging in his machine he found a leak at the bottom corner of the condenser. There was only 5 bar pressure in the system but that was recovered anyway.
So I've just ordered a new one from site sponsor, Advanced Factors. Hopefully it'll be with me tomorrow as I've paid for DHL next day - I've found AF to be very good.
I'll strip out the old one tonight and wait for the new one.... Gavin
https://www.youtube.com/@ChallengingClassics
Post #639908 17th Aug 2022 10:09am
DrRob
Did you use the discount code on check out?
AF4LRP Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #639913 17th Aug 2022 11:41am
Superspoons
AF4LRP
Damm, I missed that. Just ran it through again and the 5% would've given me £6.25 off. Will bear that in mind next order, thanks. Gavin
Post #639915 17th Aug 2022 11:46am
Superspoons
Help...
So, I've stripped down the front, took off the air con pipes, removed the slam panel and I cant get the condensor to lift up and away. It rises about 1cm and that's it. Just stops. I've looked and looked but cant see any clips holding it in on either side. It is literally just sitting there in the slot..
Can anyone advise how to get a 4.2 SC Condenser out ? Any secret clips? It's suppose to just lift out... Gavin
Post #640093 18th Aug 2022 6:50pm
Superspoons
So, just finished. Its out and the new one is in place.
Right up to follow on my main thread. Gavin
Post #640103 18th Aug 2022 9:43pm
dhallworth
Sorry Gav, just seen your post.
Worst bit of removing mine was getting the pipes out of it!
I took the radiator out of mine and then there was enough movement in the cooling pack to tip it forward and slide the condenser out of the top.
Post #640106 18th Aug 2022 10:08pm
Superspoons
No problem David. After getting the old one out I still couldn't see why it wouldn't come out - no clips on the plastic pack keeping it in Confused Gavin
Post #640121 19th Aug 2022 7:40am
