![]() | Home > Maintenance & Mods (L322) > LR set to recall all 2011MY FFRR's for new AGM battery |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
Interesting. how do I find out my NIN? Also, What is the misfire issue you describe? Thank you ![]() |
Badger Member Since: 02 Jan 2011 Location: Bucks Posts: 170 ![]() ![]() ![]() |
Sorry, fatfinger syndrome, I meant VIN !
Thanks, Badger. Mine is outside this VIN range by quite some margin so am I in theory fine? |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
Badger
Tomw2000 Member Since: 22 Jan 2011 Location: Hertfordshire Posts: 202 ![]() ![]() |
V. Quick look and I think mine does fall within that range of VINs.
Rambles you may well be right. However the update sheet (in addition to specifying the replacement battery) refers to reducing the Timed Heater says "to help prevent battery drain". So they are obviously still concerned that even with the new battery, the car may suck all the juice out.
Japseroony Member Since: 18 Nov 2008 Location: North East Posts: 426 ![]() ![]() ![]() |
WTF have LR done to my car?
HJD Member Since: 09 Feb 2011 Location: High Leicestershire Posts: 22 ![]() ![]() ![]() |
Have you tried the hot/cold roller control under the front fascia vents? I found that this makes an awful lot of difference to what comes through the front vents, even on the auto setting. MY2011 FFRR 4.4 TDV8 Vogue, Santorini Black and Ivory *Arrived*
Asking a question like that you aint a dealer are you ![]() "OVERSTEER" ------is when you hit the fence with the rear of the car. "HORSEPOWER" ----is how fast you hit the fence. "TORQUE" -----------is how far you take the fence with you. |
I know it sounds obvious....just that it caught me out for the first 3 weeks of ownership. I could never work out why it was so cold despite having the air con set at 22 degrees. MY2011 FFRR 4.4 TDV8 Vogue, Santorini Black and Ivory *Arrived*
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
Dealer has mine booked in this Thursday for new battery and software updates...have to say I haven't experienced the problems that others have had |
Jasperoony
p-trax Member Since: 30 Dec 2010 Location: Hertfordshire Posts: 261 ![]() ![]() ![]() |
had the new battery and second software update on friday. Not wishing to "temp fate" but all seems to have improved.................in as much as I listened to the DAB radio, with the engine off, for at least 30 mins with no low bat warning. Gerry
