Home > Maintenance & Mods (L405) > Oil change using vacuum extractor
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Bit of a daft question but, I am about to do an interim oil change on my L405 SDV8.
I have an oil extractor pump but am a bit unsure how the hoses connect. I have 4 tubes with rubber end pieces.
One tube is obviously too large so will ignore that. The next smallest is about the same diameter as the oil extractor tube on the engine but will not fit inside it. I can fit it to the oil extractor tube on the engine using the rubber piece as a connector and the other end will fit into the hole in the oil extractor pump. Their also a smaller pipe that will fit inside the oil extractor pipe on the engine. Finally there is a thin metal tube that I assume is for inserting into the dipstick tube where fitted.
Should I take the thin pipe and insert it into the oil extractor tube on the engine and then use the slightly larger pipe and the rubber connector to connect the pipes together and then into the oil extractor pump. Or, should I use the medium pipe (same size diameter as the oil extraction tube on the engine) with the rubber connector to connect to the oil extraction pipe on the engine and then into the oil extractor pump?
I hope this makes sense.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #640077 18th Aug 2022 4:14pm
Baltic Blue
Hope this helps… assuming you are using a Draper
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #640082 18th Aug 2022 4:33pm
IGP
Thanks Baltic Blue.
The largest pipe, that I decided to ignore, is a snug fit on the oil extractor tube in the engine.
Post #640088 18th Aug 2022 4:44pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
As above, the steel tube is vac tube so fit over the end not inside it.
I think it’s 10mm
Post #640132 19th Aug 2022 9:06am
supershuttle
I only got 8.5L out but replenished what was left with fresh oil so I'm sure it will be better than it was. Geoff
Post #640136 19th Aug 2022 9:22am
